| Home > Help Needed / General Tech Chat > Oil pump problem, anyone have any suggestions? | |||||||
![]() 163 Posts Member #: 9865 Advanced Member |
22nd Aug, 2012 at 09:55:32am
Hi guys,
22nd Aug, 2012 at 11:13:19am
I had this once on my last engine it was the oil pump gasket but just as likely to be the o-ring on the box-block join
Edited by Brett on 22nd Aug, 2012. Yes i moved to the darkside |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
25th Aug, 2012 at 09:58:23pm
I get the same with mine, oil cooler on the out rigger for front subframe, maybe it is the oil emptying from the cooler.. Main Build
25th Aug, 2012 at 10:20:36pm
for the oil to drain back, there must be air getting in, whether that is from knackered engine bearings, leaky oil system, damaged pump gasket or missing O ring between block and gearbox.
26th Aug, 2012 at 03:31:51pm
Never had this happen till I moved the oil cooler from the bottom front of the engine to the position on the brace bar..
On 25th Aug, 2012 Sprocket said:
for the oil to drain back, there must be air getting in, whether that is from knackered engine bearings, leaky oil system, damaged pump gasket or missing O ring between block and gearbox. Oil should not drain back so long as there is an oil film on the bearing journals. Works the same way as the old pub party trick where a full glass of water can be turned upside down with only a beer mat stopping from pouring out. Main Build
31st Aug, 2012 at 07:41:20pm
If the hose or hoses are in an upright. Position, there's your problem... especially the one from the feed from the block to the cooler
1st Sep, 2012 at 04:43:50pm
Hi Steve, only just seen your post is there any way to stop this, such as a one way valve or some thing.. Alan
On 31st Aug, 2012 BENROSS said:
If the hose or hoses are in an upright. Position, there's your problem... especially the one from the feed from the block to the cooler Main Build
