Home > Help Needed / General Tech Chat > Electronic distributor wiring help
boostjunkie
Member #: 9117
Northampton
Hi hoping you can help trying to wire my electronic distributor but struggling to find the correct wiring diagram! It has three wires
1(BLUE/red)
2(GREEN/white)
3(BLACK/grey)
Hopefully this picky will work...
http://s1000.photobucket.com/albums/af127/...nt=7b2393e2.jpg
ado15
Member #: 9838
According to our information, you only need to use the outer two pins on the module. The one to the left on your picture is the +ve feed (plain white wire on the car). The one to the far right is the -ve from the coil (originally white/black wire).
The easiest way is to run a pair of cables from the coil. The coil will then just need a 12v feed to the +ve side.
You should be using a DLB198 type coil.
hope this helps.
Steve
DSN Classics Ltd
www.dsnclassics.co.uk
