Home > Help Needed / General Tech Chat > Another 'fecking minis' thread...
Mike-998
Member #: 9774
Buckinghamshire
At least it's not just me that hates the bloody things sometimes...
Managed to shear the bolt in the carb that has the spring on it to hold the bimetallic jet holder, but it sheared with nothing protruding out of the hole...
Any suggestions? There isn't exactly much meat around the hole, so don't know about drilling and re-tapping... And don't want to bodge it, so I have no idea
A small easy out?
Mike-998
Member #: 9774
Buckinghamshire
Hadn't heard of those before? Just had a google, it should work, it want in there particularly tight...
Where's the best place to get them from? And is it worth getting an expensive set?
mossy2a
Member #: 9751
Derbyshire
Definitely buy a decent set. I made the eBay mistake and when they snap flush inside the thing your trying to remove its a bast@@d to remove. Luckily we have a spark eroding machine
Hammer and punch?
Craigie-B
Member #: 9468
Wootton Bassett
I still have the spare bottom end of the NA hif44 shellspeed sent to me, dont know if its of any use to you???
Quite like the thread title *wink*
Edited by Craigie-B on 24th Aug, 2012.
Mike-998
Member #: 9774
Buckinghamshire
Where have people bought them from? Bearing in mind I'm going to have to drill a 1mm ish hole because the screw is so tiny...
What do you mean by hammer and punch Gary?
And craig, if you have the bolt that hold the spring then that would be a great help?
machine mart
If there's enough exposed and its loose enough, you can rotate it using a hammer and punch.
supermotolee
Member #: 2153
kings langley
I'd use an easy out and a small blow torch from b&q to apply some heat
Craigie-B
Member #: 9468
Wootton Bassett
Ill have a look, when I get my lazt student arse out of bed
Mike-998
Member #: 9774
Buckinghamshire
Cheers Craig, I'm much the same *tongue*
There's nothing sticking out unfortunately, I'm tempted to just take it to an engineering shop to get it done, i'd rather pay than cock it up myself...
Someone suggested drilling and tapping the bolt (or what's left of it) with a left hand thread?
Here's what it looks like
Craigie-B
Member #: 9468
Wootton Bassett
unfortunatly mate the screw isnt there in the spare carb bro =/ sorry bud
Mike-998
Member #: 9774
Buckinghamshire
No worries mate, I'll try and get hold of burlen or another spare carb
