Home > Help Needed / General Tech Chat > cant get fuel pressure below 10 psi any ideas regulator has no holes / splits in diaphragm
charlieb150
Member #: 9931
brighton
any ideas ive got a lucas fuel pump from a era on it
steve1275
Member #: 951
Bromsgrove
Sounds like a restriction in the return line.
'Where does the engine go?'
charlieb150
Member #: 9931
brighton
ive got the return going straight to the filler neck at the minute lol
Draw a picture/schematic of what you're system is made of, pipe sizes etc, and what parts you are using and exactly how it is plumbed.
colas
Member #: 102
Pennsylvania USA
sounds like return too small or restricted
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Is the pump to powerful ?.
Main Build
Upgrade to Turbo
charlieb150
Member #: 9931
brighton
hi all thanks now sorted was due to a to small return thanks very much
dialup_2001
Member #: 9430
This is the problem I am having, please tell me what diameter of pipe you are using for the return and the feed. Many thanks.
you need a 8mm id return in a perfect world
