Home > Help Needed / General Tech Chat > Cutting holes in FG Clubman front for grille
topcat
Member #: 9408
Tiptree, Essex
Hey, want to chop out the hole(s) in my front end tomorrow, just wondering how much people take out? It's a 2pc Clubman front, I was thinking about cutting it out in 2 halves with about a 40mm wide strip left in down the middle for a bit of extra support, sound like a plan?
Also want to cut some round holes below the grille area, is a 2.5" - 3" hole saw about the right size to look good?
Cheeeeers,
TC
p.s. for chopping the headlight holes, is it just a case of line it up, draw round the holes and measure to check then cut?
www.topcatcustom.co.uk
You can see there what i did with mine.
topcat
Member #: 9408
Tiptree, Essex
Cheers Carl
No problem, i used the grille to mark the headlight hole locations too.
Slightly better picture from the back when i painted it.
Edited by Carlzilla on 26th Aug, 2012.
topcat
Member #: 9408
Tiptree, Essex
How do you hold the grille and headlight surrounds away from the front? As there is a big gap between the ally stuff and the front panel...
My grille is a crap fit, I think the fg front isn't very good, but grill was off a fire damaged clubman so isn't true either, gonna need some hammer bodging and/or tin snips to get it to fit!
My headlights were slightly bigger than the holes and the whole grille was screwed together. Then 4 cap head allen bolts through the grille ends and the lights space it out okay. I was going to use nuts and washers to hold them out, or some narrow tube/hose but didn't need to in the end.
Best picture ive got of how it sits but thats with mk2 golf lights. I had to trim my front end to get the grille to fit too, pain in the ass.
topcat
Member #: 9408
Tiptree, Essex
Thanks again, getting fed up with trying to make stuff perfectly go together, getting to the stage now where its a case of cut/beat it to fit, then make it look nice!
