| Home > Help Needed / General Tech Chat > Fuel pressure gauge | |||||||
![]() 328 Posts Member #: 9107 Senior Member Devon |
26th Aug, 2012 at 08:53:57am
Just wondered which one is best, I have a 0-15 psi one in the dash but it's a bit rubbish and if I run high boost ( which I intend on doing ) its not high enough . I am trying to find a 0 - 30 psi one that is ideally oil filled to stop any wavering at certain pressures. Can't be one of those digital smoked ones as the car is open topped so it's impossible to read them .
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
26th Aug, 2012 at 09:06:06am
its never a good idea to have a pressurised fuel line inside the car well i wouldnt like it if it burst all over me Done now needs redoing lol |
26th Aug, 2012 at 09:43:57am
As above, It's never a good idea to route fuel lines like that inside the cabin.
26th Aug, 2012 at 11:50:54am
You can buy a kit that transmits the fuel pressure from the fuel line, to the gauge without the fuel. Its basically a small device that has a diaphragm, you then fill the gauge and the gauge line with an oil or antifreeze and install this device on the end of the line. The device is then attached to the fuel line.
26th Aug, 2012 at 05:47:38pm
Thanks for the advise guys, as the car is a mini scamp it is very open and basic inside, as in you can see in to the engine bay ! With this in mind I got a double braded heat shielded line through the bulk head and in to the makeshift chequer plate dash ! , I really need to keep a good eye on the gauge as I know that the regulators can and do fail , I don't want to loose pressure when on full chat ! . I checked eBay but not sure how good the quality was on some of the gauges on there . I will try a local company that I got the hose from, they do all kinds of high pressure hose and stuff !
26th Aug, 2012 at 07:36:42pm
On 26th Aug, 2012 redrat said:
I really need to keep a good eye on the gauge as I know that the regulators can and do fail , I don't want to loose pressure when on full chat ! They do ? If you lose fuel pressure on full chat, your engine will stop. So you'll know about it pretty quickly anyway 9.85 @ 145mph
26th Aug, 2012 at 09:48:10pm
As I understood it if you have too low fuel pressure the mixture can lean off at boost ? I am sure I also read a thread on here about the regulators requiring adjustment as they can change after time and also fail. I know from personal experience I am on my second one , the first one was part of the spares when I first bought a turbo engine and that went after 8 months or so. But then it was out of use for an unknown number of years ! . |
27th Aug, 2012 at 10:45:28am
I never had any problems with mine during the years I used them.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
27th Aug, 2012 at 11:16:29am
Or buy an AFR gauge, more expensive but you can do a lot more with the info displayed. Dazed and Confused.... |
27th Aug, 2012 at 11:18:47am
Got an AEM wide band one after I blew the head gasket |
27th Aug, 2012 at 11:42:01am
I would be happy with an under bonnet one i have only ever looked at mine once and if you lost all fuel pressure the engine would eventualy stop anyway
Edited by Brett on 27th Aug, 2012. Yes i moved to the darkside |
) just being carefull not be be on boost for long periods
