| Home > Help Needed / General Tech Chat > Crank Pulley removal in situ? | |||||||
478 Posts Member #: 1962 Senior Member Lancaster |
27th Aug, 2012 at 06:20:01pm
How do folks
27th Aug, 2012 at 06:22:41pm
No real reason why not. At worst you may need to remove the LH engine mount and steel bracket, but there is plenty of room for the pulley to come off. 9.85 @ 145mph
27th Aug, 2012 at 06:29:47pm
I was looking at how thick the pulley is and looked at the space left with the rad out and thought 'no chance', I can see how it would come off with the engine mount off though.
27th Aug, 2012 at 06:55:02pm
I have done it steve explains it spot in you might just be able to get away with un bolting the mount from the gearbox and jacking the engine slightly Yes i moved to the darkside |
27th Aug, 2012 at 06:55:24pm
The med pulley is bigger than std, you have to grind away the engine mount holder with a burr, undo the two bolts that hold the box onto the holder thing and jack one side of the engine up, its awkward but I've dine it loads of time. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
27th Aug, 2012 at 07:45:21pm
Cheers guys, the bracket has already been modded so I can get the belt on without too much trouble. I'll try and undo it all and try again.
27th Aug, 2012 at 08:49:56pm
get the seal into the cover square and make sure it seals in the timing cover the rest should be ok, damper on before you nip the cover bolts up Edited by Brett on 27th Aug, 2012. Yes i moved to the darkside |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
29th Aug, 2012 at 05:03:43pm
I've just done this to fit a DSN alloy cover.
Metric is for people who can't do fractions. |
29th Aug, 2012 at 09:43:56pm
Springy, gappy side inwards (towards the oil).
In the 13's at last!.. Just |
5th Sep, 2012 at 08:45:10am
I've found the source of the oil leak... anyone know how i could have done this?
