| Home > Help Needed / General Tech Chat > supercharge,on the turbo lump | |||||||
![]() 281 Posts Member #: 441 Senior Member |
29th May, 2005 at 10:25:49pm
ok so im putting mt supercharger on my turbo lump,firstly,can i run it on the turbo dizzy?and second,can i leav it where it is or would i have to adjust it? stuart tells me 26 degrees on the supercharger,is this what standard turbos are usually set to?? |
30th May, 2005 at 09:32:29am
ok, the turbo was timed up to 26 degrees i beleive (stuart did it)
30th May, 2005 at 09:55:34am
it will be fine on the turbo dizzy. obviously wants RR'ig to get the best out of it but at 26degrees max advance you'll be safe enough. |
