Home > Beginners Tech > Fuel hose mounting
Mike-998
Member #: 9774
Buckinghamshire
Whats the best way of mounting the P clips under the car? Pop rivets? Self tappers?
Also, where's the best place to mount an in-line fuel pump (bosch type) and fuel filter? my original intentions were against the rear firewall/seatback but because of my spare wheel apparently that's too high?
And finally, my fuel filter is a Malpassi Regulator/Filter, but there's no return hose, so i'm not sure how it does the regulating, and how to set it to what i want.
Thanks
Edited by Mike-998 on 30th Aug, 2012.
Craigie-B
Member #: 9468
Wootton Bassett
Im going to be drilling hole in floor, then using machine screws washers and nuts to hold the p clips on :) stainless items ofc
wng691s clubby
Member #: 9252
Cleethorpes
self dilling bolts/screws
Done now needs redoing lol
I fitted mine with rivets to minimise the protrusion internally; remember to seal the drill hole to prevent rust...
