Home > Help Needed / General Tech Chat > Finding top dead centre accurately on A+
NickG
Member #: 7912
Australia oi oi oi!
So I have a 1275 A+
I for the moment wind the engine over
To find Top dead centre, I role the engine
Around until the piston is top with a screw driver.
I dont have a inspection plate on the clutch side
Unless it is painted over? but I see the arrow.
What easy way can I find TDC?
I worried about when I put the blower
On, I don't want to Be out a heap
Of degrees?
Kean
Member #: 341
aka T2clubby
South Staffs
Do you have the standard crank damper on?
Drop the rocker cover off and check that the valves for number one cylinder are shut when the piston is at the top.
Forgive me, by why does it matter with the blower?
nick what for the cam timing?
Chalkie
Member #: 9764
Northamptonshire.
You should have a small inspection plate on the clutch cover :S
Often not drilled on later housings.
hack up an old spark plug and make a dead stop.
shellspeed
Member #: 9580
Surrey
My Supercharger pulley didn't come with a timing mark. I had to make my own therefore find TDC static so as the check with a timing light would have a mark to line up with. DTI with extended probe down no1 spark plug hole is the safest I found. I double checked this when I had the head off and it was spot on.
wng691s clubby
Member #: 9252
Cleethorpes
as above dti gauge
Done now needs redoing lol
tadge44
Member #: 2500
Buckinghamshire
As Joe says, have a stop, wind the engine backwards and forwards to the stop, noting where it stops, and half way between is exactly TDC
ive recently been using the educated guess method, [no wise cracks] works for me,lol
tadge44
Member #: 2500
Buckinghamshire
I dont think guesswork would produce the results that the DON does, somehow.
I wouldn't bet against it ,lol
NickG
Member #: 7912
Australia oi oi oi!
Not sure on cam timing.
Well I wanted the timing to be close.
I feel I'm just guessing rocking the piston
To top finding where it rocks to find TDC
Surely I'm a few degrees out?
Yeah my inspection plate is blanked.
NickG
Member #: 7912
Australia oi oi oi!
NickG
Member #: 7912
Australia oi oi oi!
Hey lads.
Just a thought I still have the timing teeth
On my timing cover.
Isn't the first one top dead centre?
The each teeth is 4 degrees? Is that right?
tadge44
Member #: 2500
Buckinghamshire
That will get you somewhere near, but if you want it right there are instructions above.
