| Home > Beginners Tech > in need of some serious help newbie | |||||||
12 Posts Member #: 10093 Member |
29th Aug, 2012 at 04:29:08pm
i have read through various topics and how to guides and ever since i have owned my mini i have had a funny feeling that its been build ready for a turbo but never got to actually having a turbo fitted i need someone to clear this up for me so i dont splash out on party when they may be under my nose.
29th Aug, 2012 at 04:56:25pm
You need to accurately work out the compression ratio by measuring the piston to deck height, piston dish and head volume. bk450 head gasket is about 3.8cc.
Edited by minimole23 on 29th Aug, 2012. On 7th Oct, 2010 5haneJ said:
29th Aug, 2012 at 05:12:15pm
ok well does the metro 1300 come with dished pistons as standard i know some stuff on building but i wouldnt have a clue how to do all that could i not just do a compression test ?? |
29th Aug, 2012 at 05:30:54pm
Just get a flat piece of perspex, drill 2 small holes in it place over chamber/ piston dish (assuming the engine is split), fill with a fluid from a syringe or something you can quantify and hey presto, the amount of fluid missing when the liquid reaches the holes again is equal to the volume below.
29th Aug, 2012 at 05:31:41pm
Also mg metro pistons do look sturdy so if you can get the compression down they look like a safe bet. On 7th Oct, 2010 5haneJ said:
29th Aug, 2012 at 05:35:17pm
thanks for helpfull quick reply learned somthing already i am away from home and cant work anything out with no numbers so i will find out . ino it has been ported and polished and when new they have 26-28 cc chambers so i imagine that wont need no head work but i will see thanks.
29th Aug, 2012 at 09:37:05pm
You need to measure the head. If its had work done, it's more than likely been skimmed to increase the CR. In the 13's at last!.. Just |
29th Aug, 2012 at 11:42:26pm
Yes its been skimmed but only because of blown head gasket caused surface damage I need to.know what to measure |
30th Aug, 2012 at 08:30:34am
You need to measure the chamber volume. Combined with the volume of the piston dish, ring lands, gasket etc, you can calculate your compression ratio and work out from there what you need to do to get to an ideal ration for FI. It may well be that you could get the head further modified to suit if need be.
