| Home > Help Needed / General Tech Chat > Microbore copper pipe vs copper fuel line????? | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
30th Aug, 2012 at 09:22:49pm
Hey guys, simple Q,
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
30th Aug, 2012 at 09:33:56pm
yes mate same thing im a pipe installer on the rigs use this for generator fuel lines give em hell |
30th Aug, 2012 at 09:37:41pm
Thank you :) Okay to use for my mini yeah?
Edited by Craigie-B on 30th Aug, 2012. On 10th Mar, 2012 theoneeyedlizard said:
30th Aug, 2012 at 09:59:11pm
yeh mate i use it on mine no probs give em hell |
337 Posts Member #: 9138 Senior Member wolves |
30th Aug, 2012 at 10:02:32pm
i might have some dead sexy plastic coated stuff but will have to check bore size |
30th Aug, 2012 at 10:09:59pm
the plastic coating goes brittle after a while mate ,i personally wouldnt use it ,but you can strip the plastic coating off and then use it give em hell |
31st Aug, 2012 at 03:45:17am
I think im using 10mm microbore copper pipe a little on the large side but ovrkill is better than doing it twice Yes i moved to the darkside |
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
31st Aug, 2012 at 06:43:10am
Yes,8mm to the reg,10mm return,been on for about 5 years now.B&Q the thinking man's auto parts store! 'Where does the engine go?' |
31st Aug, 2012 at 07:36:46am
does it have l
31st Aug, 2012 at 07:38:34am
31st Aug, 2012 at 08:00:19am
31st Aug, 2012 at 06:50:34pm
I'd personally use cupro nickle pipe, rather than just plain copper, as it resists corrossion better. Copper pipes on the underside of a road car will 'fur' up On 26th Oct, 2004 TurboDave16v said:
