Home > Help Needed / General Tech Chat > Carby settings?
Aussie_Dan
Member #: 461
Queensland Australia
Can someone please give me an idea of a starting point for the mixture screw on a blow through HIF, until I can get it tuned. Also what oil should I use in the damper, as all the oil has seeped out over time?
FIVE YEARS AND ITS FINALLY RUNS!
Oil most people use is 20/50 engine oil. Wants to be something good and thick, as anything thim will disappear in no time at all!
TurboDave wrote an item in a thread a bit ago recommending an initial setting for the carb. I think he said to take the dashpot assy out, and set the jet height level with the bridge of the carb. Have a search through the forum and you will probably find it.
hi Dan,
warm the engine up and set the C0 TO 2.5% ON IDLE if its a standard turbo engine
if you have tuned it set the C0 to 5% AT IDLE
the oil in the carb dashpot most of us on hear use 20/50 engine oil.
Aussie_Dan
Member #: 461
Am I correct in assuming that the further the screw is in the leaner the mix?
the other way round dan
if you screw it in the mixture goes rich
if you screw it out the mixture goes lean
for IDLE, tickover
Edited by BENROSS on 2nd Jun, 2005.
