| Home > Technical Chat > 7 port ignition mapping issue. | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
30th Aug, 2012 at 09:35:00pm
Sorry none turbo related issue. I recently mapped my 7 port 1330 n/a engine spec
Edited by alaskanow0 on 1st Sep, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
30th Aug, 2012 at 09:40:13pm
compression wrong ? cam timing wrong ?
30th Aug, 2012 at 09:43:17pm
This 7 Port setup is currently giving me a increase of 12bhp over a nice stage 4 head with Hif44, aldon dizzy at 34 degrees.
30th Aug, 2012 at 09:43:36pm
That much timing would suggest to me that the static CR is very low. Certainly not 11:1. How sure are you on your various volumes? Did you measure them yourself to be 100% sure?
30th Aug, 2012 at 09:47:53pm
I'm 100% sure on CR, TDC and sensor position. I double checked them several times. The problem seems to be linked to the alloy head.
Edited by alaskanow0 on 30th Aug, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
30th Aug, 2012 at 09:50:19pm
whats the deck height and plug arangement? the plugs arent down holes like the mini sport heads are they? On 28th Aug, 2011 Kean said:
30th Aug, 2012 at 09:54:44pm
Ive already increase CR from 10.6 to 11-1, by skimming the head, but not really gain any more power. Class C 3rd Place Avon 2011 14.18 @101mph |
30th Aug, 2012 at 09:57:32pm
Deck height is 0.5cc, piston is vitually level with deck. The chambers have been modified to allow spark plug to be more prominent in the combustion chamber. Edited by alaskanow0 on 30th Aug, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
30th Aug, 2012 at 10:10:54pm
I'm wondering about cam timing now. I moved it from 108 to 106 degrees to compensated for 1.5 Rockers and to move torque curve slightly down the rev range. Class C 3rd Place Avon 2011 14.18 @101mph |
30th Aug, 2012 at 10:15:36pm
Pistons have 8.2cc
30th Aug, 2012 at 10:23:25pm
on a 1330 yeah.
30th Aug, 2012 at 10:25:41pm
Yes 1330. Class C 3rd Place Avon 2011 14.18 @101mph |
31st Aug, 2012 at 06:28:40am
have you made a mark at tdc on the pulley and a coresponding mark on the case ,that you are sure IS tdc ,and using a strobe on those marks ?
Edited by robert on 31st Aug, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Aug, 2012 at 07:56:08am
Yes my strobe does read double, due to wasted spark. I've taken this into account. My laptop shows 20 at idle, which reads 40 on timing gun.
31st Aug, 2012 at 08:04:48am
Why did you have cam at 108 degrees? A 286 should be at 106 anyway, and why would you need to compensate for 1.5 rockers?
I seriously doubt it! |
31st Aug, 2012 at 08:48:03am
Sorry cam is a SW10, Swiftune's version of 286, was told 108 by them. I was hoping to tame it down slightly, especially as fitting 1.5's.
Edited by alaskanow0 on 31st Aug, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
31st Aug, 2012 at 08:51:14am
Id put the timing back to 108 then otherwise your injecting the fuel with the valve in the wrong place I seriously doubt it! |
31st Aug, 2012 at 09:29:31am
can you put the timing in the ecu to 0 and see if it lines up with the tdc mark at all? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Aug, 2012 at 09:30:40am
if you do a compression check with a guage ,what do you get ?
31st Aug, 2012 at 09:48:00am
I'll have a go, but whilst I've got the head off again am going to check valve spring rates and heights.
31st Aug, 2012 at 09:54:14am
I will stick up my ignition map shortly. It's TPS v RPM only, no map compensation. I haven't managed to do a compression test due to size of spark plug hole, but no sign of head gasket failure. Class C 3rd Place Avon 2011 14.18 @101mph |
31st Aug, 2012 at 10:14:01am
Cam timing being not as specified will lose horsepower. Get that right, check fitted valve spring height and check for binding at full lift with 16 thou clearances.
31st Aug, 2012 at 10:27:20am
I've fitted 1.5 offset rockers from MED, as the valves are offset. I couldn't get hold of any 1.3's offset. I was adviced to advance cam timing to 106 by few people. I understood a may lose a few hp at top end but gain bottom end. This a road car and spends 95% below 5k. Class C 3rd Place Avon 2011 14.18 @101mph |
31st Aug, 2012 at 10:36:12am
And yes, I have come to realise this isnt really a suitable road head, but for now I just want to get the best out of it, before I probibly move back to 5 ports.
31st Aug, 2012 at 11:15:59am
Oh, dont get me wrong, the 7 port should make a better road engine than 5 port, Im just making the point that getting the mechanicals right before setting up ign and FI needs to be done and that you seem a bit dissappointed by only a 12hp increase when its a pretty good achievement on a mild engine spec.
