| Home > Help Needed / General Tech Chat > up-side-down oil cooler | |||||||
1st Sep, 2012 at 05:13:59pm
Would I be right in thinking that if your oil cooler was upsidedown and the pipes went down'ish would it drain back to the sump?
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
1st Sep, 2012 at 06:23:47pm
No. There are usually anti-drainback valves either in the filter housing or filter.
Edited by stevieturbo on 1st Sep, 2012. 9.85 @ 145mph
1st Sep, 2012 at 07:12:34pm
If you think of it like a radiator in your central heating, you have to bleed the highest point to get the air out and get the water to the top, wouldnt you have the same problem with an upside down oil cooler? I seriously doubt it! |
1st Sep, 2012 at 07:45:57pm
On 1st Sep, 2012 paul wiginton said:
If you think of it like a radiator in your central heating, you have to bleed the highest point to get the air out and get the water to the top, wouldnt you have the same problem with an upside down oil cooler? I would tend to agree, but then how do these new fangled engines not suffer with air traps in the oil filters that point upwards? I defy anyone to be able to screw on one of those oil filters after it has been filled with oil, and not spill some! On 26th Oct, 2004 TurboDave16v said:
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
1st Sep, 2012 at 10:41:56pm
Oil is a lot thicker than water, so pushes air easier, and is pressure pumped unlike water in a cooling (or heating) system. www.topcatcustom.co.uk |
2nd Sep, 2012 at 07:28:59am
Being a plumber I know what you mean paul,
2nd Sep, 2012 at 10:44:30am
I'd say the pressures involved mean air locks arent an issue. Although had never really thought about it.
2nd Sep, 2012 at 11:11:46am
You say that stevie but my mrs's dad has a spitfire and hes been looking into a filter probe that make the filter drain less when standing, as they do drain.
