Home > Help Needed / General Tech Chat > OT, suggestions for accurately cutting a worktop round a cloakroom basin
Any easy suggestions other than a little bit at a time?
Craigie-B
Member #: 9468
Wootton Bassett
ill ask my uncle he is a builder, he said use router
Craigie-B
Member #: 9468
Wootton Bassett
you could use a jigsaw, but if you use a router youd get a neater, more accurate job
Cutting isnt the issue, its where to cut to get a nice tight fit
1380rich
Member #: 9766
Warwickshire
Jigsaws your best bet mate, is it the worktop or the front panel?
Rich
Avon 2010 class c 3rd
Both Rich
Can you make a cardboard template, then use that as a guide to mark out on the worktop?
1380rich
Member #: 9766
Warwickshire
And no template? What a bastard! For the top I'd flip the basin over to draw around and measure in from all sides and then make a template for the front.
That was my initial thought Matty but I have no reference how far out from the wall for the front panel and how high for the top.
I think its the best idea though
I made a card template, and tried it in the box the unit came in to make sure its a nice fit.
You may be able to download a cad plan from the manufacturer you could get an accurate template to work from
