Home > Beginners Tech > Building first turbo
lee.pb
Member #: 9199
Lancashire
Morning all,
Final decided to build a turbo engine for my mini after having my arse handed to me by the DON at MITP.
I know there's no chance of getting towards that sort of power or times but looking for around the 140 bhp ish.
Going down the road of a mirage manifold to prevent the bulkhead require cutting so will be looking at running a T2 I think. This is my first time at building a turbo motor so expect some questions if I can't find the answers in the search section *surprised*
I currently have a spare SPI block sat around and was wondering if this could be used as a starting point for the build as there is no oil feed take off the turbo. Going for 1293cc over bore so will need pistons but what dish? Going to dry deck the block and head (don't have head yet ad the one off the SPI is just a 12g940b small valve).
Think that's enough to start, thanks for the help in advance.
SPI block is fine, you use the oil pressure take off as an oil feed for the turbo.
bennyy
Member #: 9037
Doncaster, yorkshire
Pistons I would use cast omegas 10cc, £300 from med, plan for the future, as it gets pretty addictive *wink*
Craig (seats)
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Lee mine is an spi block with the pistons benny quotes.. runs cracking on 20psi but the odd 25 psi run takes its toll on th car..
Edit: more than up to the job on a t2 and good future proofing imo because more boost will happen lol
Edited by Brett on 2nd Sep, 2012.
A T2 is capable. Of producing 160 HP with all the good guy internals but i would opt for GT1752 off a sarb
Just built one and it made 186.3 HP and a massive! 190 ft pounds of torque,
Up to press it has grenaded several people's arses out.
And that's only @16.5 pounds of boost, I thought it was enough for the road and left it at that.
Edited by BENROSS on 2nd Sep, 2012.
lee.pb
Member #: 9199
Lancashire
That's good to know. Time to start to source parts over the winter period. First of all clean block upend get it bored. Would you dry deck it before getting it bored but leave the grub screws out?
lee.pb
Member #: 9199
Lancashire
Cheers again bennyy for the seats, there in now ready for run on Monday.
lee.pb
Member #: 9199
Lancashire
http://www.med-engineering.co.uk/catalogue...ast-pistons-020
I assume this is what I need, would you surgest getting the crank re-ground and where? Don't really trust minisport.
Sorry for all the post.
