Home > General Chat > I,m back !
tadge44
Member #: 2500
Buckinghamshire
Despite the quack telling me to sit down and do bugger all for the next three weeks I have been putting a little time in in the workshop. One 1275 engine went out yesterday, back to Bristol, and the next one, a 1098, is now on the bench. Also managed to weld up and paint a wing for another club member.
Washed the KTM from three weeks ago, but I cant kickstart it yet with injury on that leg.
Drove for the first time in over three weeks yesterday and then took TMT out to re -adjust boost levels after pissing about with bleed valve pipework.
Now sits at 15 psi, rock steady on full throttle and 13:1 AFR. I can tweak the mixture a bit for Avon in a fortnight, or use Roberts choke technique to get it a little richer, if needed.
It did feel good, all the way up the gears yesterday, after so long away from it !
Van project is still stalled which is a shame as the weather has been so good the last few weeks , for spraying.
Hope you're back to full strength soon.
Good to hear you're nearly back to full health.
Will you be going to Kop hill in a few weeks?
good good. Crack on and get than van done!
mercenary62
Member #: 9937
hope your back to full power soon
give em hell
oli79
Member #: 8480
Nice to have you back Dave *Clapping*
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
steve1275
Member #: 951
Bromsgrove
Have you been watching Arnie movies whilst laid up? :cool:
'Where does the engine go?'
Welcome back
tadge44
Member #: 2500
Buckinghamshire
Kop Hill on the Sunday for sure Matt.
Thanks for all your kind comments - I expect to see a few of you at Avon to cheer on Steve and the Midget.
tadge44
Member #: 2500
Buckinghamshire
Car ran to Avon and back really well, but I did not race because 1) the queues were unbelievable and 2) it seems Avon now require a fire extinguisher as well as a crash helmet ?
Went to Goodwood on the Sunday and had a great day out, met Murray Walker and a few others but was tempted to overtake a Ferrari on the M3 and held full boost and WOT until I did (at somewhere around 30mph more than I should if you take my meaning) and its now smoking so I reckon I have done a piston -or rings.
Will do my best to fix for the hillclimb on Sunday but I have had to bail on the RR day I had arranged for Friday with Craigie B.
steve1275
Member #: 951
Bromsgrove
Ah,red mist syndrome again David.Hope the damage is not too serious,how long were you on WOT?
Haha nice one dave!
I think im heading over to Kop Hill on the Saturday now, the spitfire fly by has swayed me. :)
Are you running it up the hill? Im taking the mk1 along, not sure if they'll let me run it though?
tadge44
Member #: 2500
Buckinghamshire
WOT for about a mile, but it was worth it to see the Ferrari drivers face.
I was privileged to sit in the cockpit of one of the Memorial Flight Spitfires at Goodwood, by invitation of the pilot.
If you are not pre-entered Matty, you wont get on the hill - and entries closed months ago.
Thats a pisser, but by the sounds of it worth it!
I thought about your a35 the other day, when I saw an A35 pickup at a show, It looked pretty cool as well and was crying out to be turbo'd!
Advantage
Member #: 1450
Near Paris - France
Fancy period car : XXX£
Full resto : XXXX£ x god konws how much time
Turbo conversion : XXX£
Replacement of blown gearbox : XXX£
More boost evolution : XXX£
Rebuilt of engine n°1 : XXX£
better turbo evolution : XXX£
Rebuilt of engine n°2 : XXX£
Fancyer head : XXX£
Rebuilt of engine n°3 : XXX£
Injection : XXX£
Rebuilt of engine n°4 : XXX£
: Priceless
Rusty by nature
Good skills Dave.
tadge44
Member #: 2500
Buckinghamshire
No skill involved Andy, other than pedal to the metal.
Replaced No3 piston with a "new" one and all is well again (I hope, as it will be WOT again tomorrow at the Kop Hill hillclimb)
Seems to be leaking even more oil now, so yet another engine change looms.
May have to use the engine set aside for the van as that seems to be going nowhere fast.
steve1275
Member #: 951
Bromsgrove
Good luck for tomorrow.That was a snappy piston change,what did the removed piston look like?
im at kop tomorrow david , weather dependant.
tadge44
Member #: 2500
Buckinghamshire
Piston only slightly scuffed, but one broken ring (det ?)
I think the extra oil leaks were all down to increased blow by.
Head and sump come off an A35 easily as there is no cross member beneath the engine.
I will be at Kop Hill whatever the weather - and it promises to be less than good.
