| Home > Help Needed / General Tech Chat > Valve clearances | |||||||
3rd Sep, 2012 at 07:33:47am
Just after peoples opinions on what to set them at. The cam is a 274 @ 112° with 1.5 roller rockers. The manufacturer recommends 0.012, but the seams a little tight to me. It's going on my gay supercharged engine, so no turbo to get in the way of the exhaust flow. On 11th Feb, 2015 robert said:
3rd Sep, 2012 at 07:35:41am
Im guessing the 12 thou is from the cam manufacturer, that would be for standard rockers so you need to multiply that to the 1.5 rockers which makes 16 thou
Edited by paul wiginton on 3rd Sep, 2012. I seriously doubt it! |
3rd Sep, 2012 at 08:01:05am
The cam is one from Stuart Gur. He recommend 12 based on the 1.5 rockers. On 11th Feb, 2015 robert said:
3rd Sep, 2012 at 08:05:49am
Id do what he says then I seriously doubt it! |
3rd Sep, 2012 at 02:00:23pm
andy its an easy change after if they are too tight. cant wait to see what this produces with the 112 LCA cam in I run a supercharger and I don't care the TB is on the wrong side.
3rd Sep, 2012 at 02:15:41pm
Me too. The headline banana and curly wurly figures should happen pretty quickly once it's on the road, but I reckon me and John will be spending a long time getting cruise and part throttle right to get the best out of it.... On 11th Feb, 2015 robert said:
3rd Sep, 2012 at 02:21:15pm
You will be spending no time on it when baby Bellamy arrives! lol If something is worth doing, it's worth doing half of. |
3rd Sep, 2012 at 02:23:07pm
i would guess that the over-run will also need some attention, as on my carb'd car it can still pull fuel when the throttle is snapped shut which used to make the car stall at junctions due to becomming way to rich.
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
3rd Sep, 2012 at 05:51:50pm
I have a piper cam and 1.5 rockers.I run .010 inlet and .012 ex but a bit 'loose'.It seems fine.I tried opening these up by the increased ratio but it sounded very rattly to me. 'Where does the engine go?' |
3rd Sep, 2012 at 06:11:11pm
Thanks Steve, that's reassuring. On 11th Feb, 2015 robert said:
3rd Sep, 2012 at 06:57:45pm
14thou
3rd Sep, 2012 at 07:18:28pm
On 3rd Sep, 2012 apbellamy said:
Just after peoples opinions on what to set them at. The cam is a 274 @ 112° with 1.5 roller rockers. The manufacturer recommends 0.012, but the seams a little tight to me. It's going on my gay supercharged engine, so no turbo to get in the way of the exhaust flow. Are you sure Kent recommend 0.012"?......................... cos their catalog has it at 0.016".................... On 26th Oct, 2004 TurboDave16v said:
3rd Sep, 2012 at 07:35:50pm
On 3rd Sep, 2012 Sprocket said:
Are you sure Kent recommend 0.012"?......................... cos their catalog has it at 0.016".................... No idea what Kent recommend as I didn't get it from them... On 3rd Sep, 2012 apbellamy said:
The cam is one from Stuart Gur. He recommend 12 based on the 1.5 rockers. Although I am aware it may have come from them originally.
3rd Sep, 2012 at 08:53:26pm
work back from the standard vlalve clearance value and then recalculate for the 1.5 rockers, can't go far wrong with that.
