Home > General Chat > 12G202 head whats it worth?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
as above, the head is rusty but looks like a bead blast will clean it up i cant see any cracks in its current state all valves move freely its got double springs look to be in good state valve seats will need a freshen up ect stock head from what i can tell
i can get it for $55 ausie if its worth getting that is
http://img.iwascoding.com/1/2012/08/26/23/...35DD71658D7.jpg
http://img.iwascoding.com/1/2012/08/26/A4/...9678CC75C45.jpg
http://img.iwascoding.com/1/2012/08/26/57/...34AA287C4A9.jpg
Edited by Turbo This.. on 4th Sep, 2012.
mattsmadmini
Member #: 9965
Sydney, Australia!
You are in Brissy Josh? Drop in and see Matty Reed, he'd sort you out with a nicer base 202, ive got 3 or 4 on my shelf but im in sydney....
That one is salvagable with a molases dip or a light acid dip to remove scale and rust, id still want to spend a couple hundred bucks on some new valves and seats at least...
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
yeah im about an hour from the city tho. ive got 3 202 heads already but i was more interested in if it was worth the hassle but ive since pased up the offer as im working on one i already have started to mod for my 1098 turbo build that is if i can find some dam pistons ! ive thought about having the head cut to alow a 998 piston to pass throw the block into the head but some how miss the gasket ? i dono i need to do more reading about what people do with 1098 turbos.. but yess matty r whould prob know some stuff to help me how do i get onto him?
mattsmadmini
Member #: 9965
Sydney, Australia!
0407 135 656
his mobile number, as for pistons, he'd put you in the right direction for them as well, would probably suggest hypatecs
http://www.ausmini.com/forums/viewtopic.ph...=turbo&start=15
That's Benjamin's 1100 turbo'd clubby, he's down here in Sydney (he also lurks around here....) Happy days!
