Home > Help Needed / General Tech Chat > Mega Jolt Kit
lee.pb
Member #: 9199
Lancashire
whats your thoughts on this MJ kit?
http://www.ebay.co.uk/itm/Complete-Megajol...1#ht_872wt_1185
currently in the process of sourcing parts and cost for a mirage turbo conversion, was thinking of getting the MJ kit now and fitting on mini until engine built. will give me some time to get to know the MJ before turbo transplant.
t@z
Member #: 452
Chester, UK
expensive
www.twitter.com/lilpinkiy
mossy2a
Member #: 9751
Derbyshire
^^^^agreed
Very..
lee.pb
Member #: 9199
Lancashire
thanks for the heads up guys, what should you be looking at for a MJ / edis 4 etc. In no rush may just post a WANTED item.
bennyy
Member #: 9037
Doncaster, yorkshire
My edis and coilpack cost me 40 for both, you can get them even cheaper if you can be bothered to go to a scrap yard.
Lee, be warned, for na you need the throttle position sensor (tps) version , whereas turbo you need the manifold absolute pressure (map) version
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
lee.pb
Member #: 9199
Lancashire
thats was going to be my next question, uuuuuummmmmm you know toooooo much lol
think i'll source the bits over a longer period and just bite the bullet and buy the pistons *happy* at least i can start to build the block.
whats your thoughts on centre main straps?
bennyy
Member #: 9037
Keep an eye out as you get some good deals on here.
My opinion is, for the sake of 30odd quid, may aswell fit one, I had one on mine, but others say don't bother, there not needed, its upto you
lee.pb
Member #: 9199
Lancashire
i'll keep an eye out for a MJ / EDIS4.
dont you have to get your main carrier machined to fit a centre strap?
bennyy
Member #: 9037
Yeah, cost me 30 all in iirc, its upto you mate.
lee.pb
Member #: 9199
Lancashire
for that cost i'll probably get it done, did you get it machined at a local shop?
bennyy
Member #: 9037
Benross sorted it all out for me, he's the one to ask.
You can use a map version for na so if you want to buy.that now and use it again later on tbe turbo engine
Edit: should say.you can use map for either n/a or turbo but you can only use tps for.n/a
Edited by Brett on 5th Sep, 2012.
lee.pb
Member #: 9199
Lancashire
going to keep an eye out for one. hopefully one will come up relatively cheaper than £350
