Home > Help Needed / General Tech Chat > GT17 <> Manifold
t@z
Member #: 452
Chester, UK
Just a quick question....
The gt17 hot side has threaded stud holes so i assume you drill these out; however there's one that looks like a right bitch to get a nut on. Simple as just grind a bit away or is there a trick to this?
T
www.twitter.com/lilpinkiy
eden7842
Member #: 8852
leicestershire
What manifold are you using mate?
Yep you can grind away a little notch. I'll try and get a pic of mine.
t@z
Member #: 452
Chester, UK
just using one of mattys; thanks matty that would be awesome i'll just copy that then :)
