| Home > Help Needed / General Tech Chat > Post head gasket change - milky oil | |||||||
![]() 117 Posts Member #: 9966 Advanced Member Norwich, Norfolk |
5th Sep, 2012 at 09:12:37pm
Evening guys,
5th Sep, 2012 at 09:33:52pm
It could just be a bit of left over moisture in the engine, it all depends on how well the old oil was flushed out, did you poor in any the rocker cover and let it drain straight out? How much mayo are we talking?
5th Sep, 2012 at 09:39:50pm
Not loads of mayo, I was more bothered by the milky colour of the oil on the distick!
![]() 26 Posts Member #: 10079 Member Chelmsford, Essex |
5th Sep, 2012 at 09:56:09pm
when my head gasket went recently I emptied all milky oil out first, had the head cleaned up & checked etc. I put some old oil back in from my previous oil change along with some flushing agent and ran the engine on idle for 15-20 minutes then drained again and changed for fresh oil. Havent had any mayo or milky oil in the sump since... |
5th Sep, 2012 at 10:23:10pm
What oil are you using? |
5th Sep, 2012 at 10:41:20pm
20w50 but it's cheap stuff. Better to switch to a good brand?
6th Sep, 2012 at 05:46:37am
when my one when i just dropped the mayo cold put some cheep home brand oil in from the supermarket along with some oil flush let it idle till at operating temp went for a quick soft drive to clear out the sump/dif/gear set and spray some oil up the block drooped it filled with good oil job done
6th Sep, 2012 at 07:39:36am
Thanks guys, another oil change this weekend then with some oil flush.
6th Sep, 2012 at 08:59:22am
the reason I asked is that the Halfords stuff has given this issue in the past for a few others.
6th Sep, 2012 at 10:00:33am
Ah ok. Well it was the cheap stuff from the local motor factors.
6th Sep, 2012 at 10:23:15am
Get the engine hot then drain the oil out, it drains easier as its thinner and it should help some of the water evaporate out.. Jack the passenger side of the car up to get every last bit out.
Edited by matty on 6th Sep, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Sep, 2012 at 01:53:37pm
thanks for your help guys, will report back after. |
10th Sep, 2012 at 12:42:55pm
Just thought I'd round this one off - did the oil change on saturday, all now clean as a whistle.
