Home > Help Needed / General Tech Chat > temp
Zeemax Power
Member #: 393
Oulton Park
where you lads put the tempture sensors? cos theres no sensor space in the block on mine with being an injection??
http://www.Zeemax.com
Nick
Member #: 154
Midlands
you could always use one of the sandwich plates on a stat housing. mine had one as standard being a 91 cooper, it was a switch for the leccy fan. pretty sure you should be able to take it out and fit a sender of your choice.
Get an early Mk1 850 Mini thermostat housing. It's got a facility for such a sensor.
