Home > Help Needed / General Tech Chat > Is it normal for my Car to not turn off when i pull the key out in limp home mode?
Craigie-B
Member #: 9468
Wootton Bassett
Okay so when i start the car it runs and everything is good, but when I go to turn it off and pull the key out it still carries on? Coilpack gets power from MJ, both this and EDIS get power from the aux fusebox which I can visually see has no power after I pull the key out. The MJ led goes off and so does the afr guage
Is this normal for limp home mode?
Edited by Craigie-B on 7th Sep, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
how long does it run on for??
Done now needs redoing lol
It's usually caused by an air leak or dodgy ignition timing. get a map on your megajolt and see his it is then.
Mike-998
Member #: 9774
Buckinghamshire
It's not, no. This was happening to me when I first fitted the megajolt, and I had connected it to a permenant live rather than an ignition live.
I'd just check that everything is definitely connected to an ignition live? Sure the EDIS isn't on a permenant live?
metroturbo
Member #: 989
North Yorkshire
Are you sure this isn't just the usual A series running on problem? Does it chug away like an old traction engine after you turn the ignition off?
Edited by metroturbo on 7th Sep, 2012.
Craigie-B
Member #: 9468
Wootton Bassett
Yeah it does a bit mate, how do i fix it?,
New pistons so i wouldnt of thought it would have carbon deposits?
too much advance?
Craigie-B
Member #: 9468
Wootton Bassett
worked out its down to the relay that I have setup soooo I need to take a look at it tomorrow =]
