| Home > Help Needed / General Tech Chat > GT1752 Stansard actuator Question | |||||||
33 Posts Member #: 3415 Member Herne Bay, Kent |
7th Sep, 2012 at 04:11:19pm
A quick question chaps, Ive had aquick search but didn't find the answer.
Edited by mattyc33 on 7th Sep, 2012. |
7th Sep, 2012 at 04:24:59pm
It'll be fine. Any more and you may need a restrictor in between the compressor housing and actuator though. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Sep, 2012 at 04:30:44pm
thanks for the quick reply, I'll fit the standard one then and ill keep a restictor in mind. |
7th Sep, 2012 at 04:34:41pm
I couldnt get either of mine to hold more than 12psi even with a lot of preload and the hose pulled off Yes i moved to the darkside |
7th Sep, 2012 at 04:48:10pm
Mine topped out at 10psi but that is what bleed valves are for. |
7th Sep, 2012 at 05:21:13pm
my stock gt17 one shoots round to 25psi + with no probs .just need a small enough restrictor and a big enough bleed valve . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
7th Sep, 2012 at 06:58:52pm
Mines seen 25 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
7th Sep, 2012 at 07:04:35pm
On 7th Sep, 2012 robert said:
my stock gt17 one shoots round to 25psi + with no probs .just need a small enough restrictor and a big enough bleed valve . Ditto. The upside down skip had a 2 bar gauge and it saw the end of the scale once or twice... On 11th Feb, 2015 robert said:
7th Sep, 2012 at 09:21:48pm
thanks for all your help guys.
8th Sep, 2012 at 08:02:09am
We used a 0.8mm welding tip, but it made it very sensitive. Turning it an 1/8th of a turn took you from actuator to 18-20 psi...
8th Sep, 2012 at 08:26:37pm
Im sure I used a fuel jet out of an SU. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Sep, 2012 at 08:50:35pm
i used some brake pipe and kept crushing it untill 1/2 a turn gives me 50% more boost (on a 15psi actuator) its easy to work out in my head then what boost i will get without guessing.. not that i use a bleed valve Yes i moved to the darkside |
9th Sep, 2012 at 09:24:59am
one thing i found is , if you just ram the jet down the pipe ,and use it that way ,there can be leakage around the jet ,which gives the effect of the jet being bigger than it really is .
Edited by robert on 9th Sep, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Sep, 2012 at 08:26:56pm
so lots of options for a restrictor then! thanks for all your help!
10th Sep, 2012 at 06:20:29am
yup !lol Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
lol
