| Home > Help Needed / General Tech Chat > ultralight Verto flywheel | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
10th Sep, 2012 at 01:48:46pm
i am having terrable problems trying to find a new ultralight VERTO flywheel with a inerta ring gear.
"Tuning should be a compromise between what is possible and what is necessary"
10th Sep, 2012 at 02:10:20pm
Easier to go pre-engaged and change your starter setup? If something is worth doing, it's worth doing half of. |
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
10th Sep, 2012 at 02:11:03pm
http://www.jonspeedracing.co.uk/index.php?...=14464&cID=2087
Pedro Silva
10th Sep, 2012 at 02:17:28pm
tried MED?
10th Sep, 2012 at 05:56:16pm
On 10th Sep, 2012 sim_ou_nao said:
http://www.jonspeedracing.co.uk/index.php?webpage=product_detail.php&product_id=14464&cID=2087 You can change the ring gear... You would buy one of those frome somewhere that can't even host a decent picture of their own product rather than that squashed ebay pixel? Edit* Nevermind the fact that the description doesn't match the picture. Edit** and they are more expensive than the MED one. Edited by Sprocket on 10th Sep, 2012. On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2012 at 06:17:54pm
What the fuck? Jonspeed are utter shit.
In the 13's at last!.. Just |
10th Sep, 2012 at 07:14:56pm
MED website says Pre engaged only, but shows the ring bolted on. Can't be that hard to change... On 11th Feb, 2015 robert said:
10th Sep, 2012 at 07:49:43pm
when I bought mine they said there would be a wait for one with the intertia ring so I said send it without the ring on and I'd fit it,
10th Sep, 2012 at 07:55:12pm
I stand corrected :)
10th Sep, 2012 at 08:11:34pm
when i said I wanted one with an inertia ring, they said "why on earth would you want one with the inertia gear?!"
10th Sep, 2012 at 09:26:18pm
Lol In the 13's at last!.. Just |
10th Sep, 2012 at 09:31:47pm
On 10th Sep, 2012 Joe C said:
when i said I wanted one with an inertia ring, they said "why on earth would you want one with the inertia gear?!" lol and you should have replied, because I don't want to have to spend £180 on another hi torque starter with the right number of teeth, when i can buy a ring gear at a 1/4 of the price with the right number of teeth On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2012 at 10:21:20pm
thats the jist of what i said to him!
11th Sep, 2012 at 07:40:12am
yer sorted with a med one now after a fassion but they came through in the end.
11th Sep, 2012 at 12:21:24pm
ok the guy from med has offered me one but it is one they are remving the old ring gear off ove they are intending to remove it then redrill it and put it in another position my question is will this effect the flywheel they seem to be avoiding comitting to any sort of answer
11th Sep, 2012 at 12:39:58pm
that will be fine imo On 28th Aug, 2011 Kean said:
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
11th Sep, 2012 at 06:23:38pm
I bought one last week from MED. He told me the chinese ring gear affects the balance, so will needs balancing. |
11th Sep, 2012 at 07:38:10pm
12th Sep, 2012 at 09:36:04am
in peoples opinion is ultra light requiered i have a lightened one as it stands for the verto cluches but have been using an ultralight pre-verto in recent times. however now i am building a RTC
12th Sep, 2012 at 09:45:47am
As a matter of course I would balance a flywheel (preferably the entire rotating assembly) If something is worth doing, it's worth doing half of. |
12th Sep, 2012 at 10:29:09am
im deffinatly balancing the flywheel but the rest of it is in the car "Tuning should be a compromise between what is possible and what is necessary"
17th Sep, 2012 at 12:34:32pm
does no one other than med and johnspeed do these? "Tuning should be a compromise between what is possible and what is necessary"
17th Sep, 2012 at 01:00:09pm
MiniSpares... http://www.minispares.com/product/Classic/...k%20to%20search Pedro Silva
432 Posts Member #: 7856 Senior Member Essex |
9th Dec, 2012 at 09:04:17pm
Just bumping this back up to the top, what kind of light weight verto's are people running with RTS set-ups?
