| Home > Help Needed / General Tech Chat > T3 turbo with a cosworth 0.48 housing??? | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
10th Sep, 2012 at 05:30:38pm
Sorry guys just wondered if i could pick your brains. I have been offered a Re-manufactured garrett t3 turbo - -31 actuator - 360 degree bearing - 0.48 cosworth housing.
10th Sep, 2012 at 05:34:48pm
thats going to be quite laggy, might be good for big power but might not com on bost properly till 5 k....
10th Sep, 2012 at 05:36:15pm
worth a shot though if its cheap, as long as you report back! On 28th Aug, 2011 Kean said:
10th Sep, 2012 at 05:40:42pm
Thats what I thought. worst case, could I just buy a rs turbo housing and fit that?.
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
10th Sep, 2012 at 06:30:12pm
I ran a T3 with the .48 housing and it was fine with mapable ignition, made good power too. 16V project underway |
10th Sep, 2012 at 06:34:28pm
On 10th Sep, 2012 Turbo Tim said:
I ran a T3 with the .48 housing and it was fine with mapable ignition, made good power too. Reheheally? Interesting. When did it boost? If something is worth doing, it's worth doing half of. |
10th Sep, 2012 at 08:32:07pm
I used one a couple of years back. It was awesome at the brunters day but a pita to get off the line. |
11th Sep, 2012 at 03:17:02pm
So in all it would be reali good top end but very laggy and not great down low?.
11th Sep, 2012 at 03:19:18pm
Wheel would need changing too so would want balancing. If something is worth doing, it's worth doing half of. |
11th Sep, 2012 at 03:25:24pm
right ok ta. might be better off leaving it to turbo techniks then. |
11th Sep, 2012 at 04:16:45pm
if its the same wheel as a metro turbo ,then the housing would swap ,no problem ,no dissasembly of the wheels would take place .
11th Sep, 2012 at 10:54:31pm
T3 is the turbine size, you dont mention what compressor is fitted to it.
11th Sep, 2012 at 10:57:39pm
to add, just seen the egay link.
12th Sep, 2012 at 06:07:17am
So who reckons I should gamble on it if its cheap |
12th Sep, 2012 at 06:35:20am
Give it a go! If something is worth doing, it's worth doing half of. |
12th Sep, 2012 at 07:47:43pm
It's already at £82 and £15 postage. That's almost £100.
13th Sep, 2012 at 05:19:18pm
Is it simple enough to change over to a different turbo?. |
13th Sep, 2012 at 07:08:36pm
On 13th Sep, 2012 turbo22 said:
Is it simple enough to change over to a different turbo?. Well...not as simple as sticking with an old T3 based unit. But anything is possible 9.85 @ 145mph
