| Home > Help Needed / General Tech Chat > Fuel Pump relay wiring :( | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
11th Sep, 2012 at 07:52:49pm
Hey guys,
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
![]() 26 Posts Member #: 10079 Member Chelmsford, Essex |
11th Sep, 2012 at 08:40:51pm
do you have a multimeter or voltmeter? check for 12v on teminal 85 & terminal 87 when ignition is on.
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
11th Sep, 2012 at 09:05:47pm
if i understand it right, the fuel pump runs during cranking and the megajolt will ground the relais at 500 rpm to keep the pump running.
12th Sep, 2012 at 05:23:38pm
I will try with a straight earth, but the idea of the circuit is that the fuel pump run when the starter motor is running and then that will start the engine making it run higher than 500rpm so then the megajolt grounds the coil connection and thus making a circuit for when the key is on ign and the engien is running On 10th Mar, 2012 theoneeyedlizard said:
12th Sep, 2012 at 10:00:45pm
try it and see what happens. with straight earth the pump should start by just turning the ignition on. If it still doesnt start then you need to investigate your ignition supply to the relay coil.
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
12th Sep, 2012 at 10:21:25pm
saved this link a while ago form Richards turbo van build may be of use for you...
13th Sep, 2012 at 06:36:13am
The circuit gets its ign live from the same place as the megajolt as ive wired in an aux fusebox On 10th Mar, 2012 theoneeyedlizard said:
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
16th Sep, 2012 at 12:25:59am
Follow the link to my wiring diagrams above mate and check out the two cranking and normal running circuits. Hopefully they'll help you.
16th Sep, 2012 at 09:56:26am
The circuit shown should work, but there is clearly a problem with what you believe is an ign live.
18th Sep, 2012 at 06:35:12am
fixed it yday, was a blown fuse *facepalm* On 10th Mar, 2012 theoneeyedlizard said:
18th Sep, 2012 at 12:37:19pm
On 18th Sep, 2012 Craigie-B said:
fixed it yday, was a blown fuse *facepalm* First thing i check when i go to a job. Flew out few weeks ago to a job, took a massive spare with me (just in case) in the end it was just a fuse. Was first thing i checked |
