| Home > Help Needed / General Tech Chat > SC engine keeps bogging down | |||||||
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
12th Sep, 2012 at 10:25:20am
Hi guys,
12th Sep, 2012 at 10:30:41am
I had a problem on my old mini. It would be fine until the engine bay temps git really hot, then it would splutter and die. In the end I had a plug lead that was breaking down. Replaced with new good quality leads and it was fine ever after. On 11th Feb, 2015 robert said:
12th Sep, 2012 at 11:01:09am
If the engine still runs and all cyclinders are pretty much firing, but it 'bogs down' lacks power but does not 'hesitate' its likely very rich. If on the otherhand it pops farts misfires and hesitates with a jerky motion, its likely very lean On 26th Oct, 2004 TurboDave16v said:
12th Sep, 2012 at 11:23:37am
Purchase a wideband O2 sensor. There is no excuse to not have one, they are cheap, good insurance, and will provide diagnostic feedback on issues like this. On 17th Nov, 2014 Tom Fenton said:
12th Sep, 2012 at 12:42:10pm
As the gents state above, also first check out the coil and all the ignition etc so you have eliminated anything. There.
12th Sep, 2012 at 02:19:08pm
Ok thanks guys.
12th Sep, 2012 at 02:26:04pm
The AEM is a popular one on here. That price seems about the average. On 11th Feb, 2015 robert said:
![]() 580 Posts Member #: 9580 Post Whore Surrey |
12th Sep, 2012 at 03:05:24pm
Hi Nick
12th Sep, 2012 at 04:13:30pm
James how would i know if the carb is worn? i did replace most of the internals before fitting it.
12th Sep, 2012 at 06:52:23pm
Side to side movement on the butterfly spindle.
12th Sep, 2012 at 07:38:15pm
No matter what you do, having the carb so far away from the inlet is going to cause you problems. His design although clever is fundamentally flawed IMHO. On 11th Feb, 2015 robert said:
12th Sep, 2012 at 07:44:38pm
Carb icing ?
12th Sep, 2012 at 08:21:21pm
British weather isn't exactly the best... Edited by Nick warwick on 12th Sep, 2012. |
21st Sep, 2012 at 09:58:13am
Tested my fuel pressure, its running at 3psi and i replaced a fuel pipe going from the fuel tank to the fuel pump as it was kinked over restricting the flow quite badly.
