Home > Help Needed / General Tech Chat > Baseline dyno results from yesterday ....
nerdhotrod
Member #: 9598
Im happy with the results. 100ish wheel hps and 105ftlbs @ 6 psi.
For reference this is a stock metro turbo engine, turbo, slightly modded carb and a 2 inch exhaust.
More boost, intercooler, water injection and blowoff valve are up next!
looks very smooth ,what dyno was this ?
That's good. More power for less boost than the standard setup.
nerdhotrod
Member #: 9598
Its a mustang md-500-se. Very fairly popular in the US.
nerdhotrod
Member #: 9598
I spent a bunch of time just making things as optimized as I could. I think there's a bunch of power left in this set up even at low boost.
The car is surprisingly quick even at this power level!
mini.cooper998
Member #: 3772
Wigan
what carb mods did you do
nerdhotrod
Member #: 9598
Converted an NA carb to turbo, basic profiling of needle to get close to desired a/f and played with different dash pot oil weights (this one is still a work in progress... its leaner then I want on boost onset).
I tuned 5-20 efi cars a week as my profession... This is the first carbonated turbo car I have ever tuned.
