| Home > Help Needed / General Tech Chat > Can someone give me a dimension from a rear subframe please... | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
14th Sep, 2012 at 10:01:52am
Hey, I'm fabricating a rear beam, and have already stripped my old subframe down. Can anyone help with a measurement giving me the width between backplate mounting flanges/stub axles so I can weld mounts in?
www.topcatcustom.co.uk |
114 Posts Member #: 9645 Advanced Member South Wales |
14th Sep, 2012 at 10:08:52am
Haynes book I have gives following:
14th Sep, 2012 at 10:36:49am
Search Google images, there are dimensional drawings for both frames out there On 11th Feb, 2015 robert said:
14th Sep, 2012 at 11:39:38am
Thanks for the replies, it is for the hub dims not the subframe ones, will try google now!
Edited by topcat on 14th Sep, 2012. www.topcatcustom.co.uk |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
14th Sep, 2012 at 03:17:58pm
I have just put a tap across and I make it 43.1/2 inches, in old money.. Alan Main Build
14th Sep, 2012 at 03:21:55pm
Cheers Alan www.topcatcustom.co.uk |
14th Sep, 2012 at 03:43:19pm
Think this may help |
15th Sep, 2012 at 10:31:59am
Thanks but doesn't show the radius arms or hub positions, subframe mounts aren't a problem just getting the dim between the rear hubs. www.topcatcustom.co.uk |
15th Sep, 2012 at 12:02:16pm
Oh right okay sorry |
15th Sep, 2012 at 04:31:43pm
On 14th Sep, 2012 topcat said:
Thanks for the replies, it is for the hub dims not the subframe ones, will try google now! Edit: no luck, this is the dimension I want (in red), face to face where the backplates bolt on ideally!
p.s. I know this isnt a standard subframe but dims should be the same https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th Sep, 2012 at 05:07:38pm
Hey, no I just nicked the image from google, I'm making one like it though, still scratching my head as how to do the bearings so they are adjustable in 2 planes, most I've seen dont look strong enough to me.
25th Jan, 2013 at 04:46:04pm
Can anyone confirm Alan's 43.1/2" measurement before I start cutting and welding?
25th Jan, 2013 at 05:58:05pm
That is mintec usa rear beam setup Drives
8th Feb, 2013 at 08:52:36am
Just thought I'd put a pic up- nearly finished radius arm, just got to weld flange on for brake backplate, press the stub axle in and put extra damper support in.
8th Feb, 2013 at 09:15:22am
I like the look of that Min Tec setup. Wonder what it weighs? If something is worth doing, it's worth doing half of. |
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
8th Feb, 2013 at 09:23:32am
thats looking really good. nice work! cds or t45? Avon 2010 class c 3rd
8th Feb, 2013 at 11:28:11am
Cheers, CDS, the smaller OD tube actually passes through the 1.5" stuff and is fully welded to the hub, so there is twice as much weld on there as appears, which should make it much stronger as I was concerned about the original design. www.topcatcustom.co.uk |
8th Feb, 2013 at 11:41:32am
Do you know the weight and do you think it will cope? Miniminor63 put alot more supports on his setup after being advised the A style was not strong enough. Drives
