Home > Help Needed / General Tech Chat > Manifold/turbo blowing
TurboMike1992
Member #: 9928
Hartley, Kent
Ever since I've been running my t3 standard setup I've had a slight blow on the exhaust manifold-turbo joint,
I inspected it and the mating surfaces on both sides appeared to be rather pitted with an uneven surface, managed to scrape back most of the carbon build up to make it a bit better.
Was just wondering if anyone has come across this and has any tips ideas on how I can stop it from leaking?
Low boosting for now.
wng691s clubby
Member #: 9252
Cleethorpes
there is a gasket you can use
http://www.ebay.co.uk/itm/T3-TURBO-GASKET-...=item4ceb5de51f
Edited by wng691s clubby on 17th Sep, 2012.
Done now needs redoing lol
TurboMike1992
Member #: 9928
Hartley, Kent
It's got a gasket i replaced when building thanks.
I was referring in terms of like maybe a fire putty I could use? Or a method of flattening off the mating surfaces
Ive found ust firegum and no gasket works well, or making a gasket from copper.
wng691s clubby
Member #: 9252
Cleethorpes
if you have tightend it down enough the gasket should seal it, you could try some exhaust putty or sending the turbo and manifold to have both faces machined
tadge44
Member #: 2500
Buckinghamshire
I do what Joe C says
TurboMike1992
Member #: 9928
Hartley, Kent
Okay cheers joe. My dad suggested maybe using some "quicksteel" to fill in the pits to bring it up to a neater level.? Could possibly work?
Even so, appreciate the ideas people :)
Have the surfaces machined flat. Job done, and not fucking about with stupid sealants which will never work.
Yes, get the surfaces machined and then use a new gasket......as good as new then.
i hand filed mine then finished the bits off on an oil block ( sharpening stone) i also have a home made annealed copper gasket @1mm no gunk stuff and not a single spot of leakage
TurboMike1992
Member #: 9928
Hartley, Kent
I'll go down that route then and get it sorted for good rather than have to rip it off again in the next fortnight. Lol
Cheers guys!
TurboMike1992
Member #: 9928
Hartley, Kent
Also Brett, how long did it take by hand?
If I can do it myself I will :)
20 mins with the file i did it on the exhaust manifold to head flanges aswell as the centre branch had warped no exhaust gasket issues for me ( i used the same gasket 5 times atleast aswell *happy* )
TurboMike1992
Member #: 9928
Hartley, Kent
Oki doke I'll look into that when I sort out my proper turbo head!
I had that issue to start off with when I used a "quality metro turbo gasket kit" which supplied a cardboard mani gasket, went and brought one of the perforated ones and worked fine :)
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I used a file and, belt sander, then a fine smear of fire gum..
Edit. With a new gasket of coarse..
Edited by nala56 on 18th Sep, 2012.
Main Build
Upgrade to Turbo
just remembered i invested in a 9inch angle grinder this worked a treat when building bennys engine
TurboMike1992
Member #: 9928
Hartley, Kent
Also would this be the reason it's taking over 4000 rpm to get full boost?
Sounds about normal for a t3
