| Home > Help Needed / General Tech Chat > Tubular radius arms- bearings. | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
19th Sep, 2012 at 11:14:15am
Hi all. I've been planning it for ages, and nearly ready to start making up my radius arms from CDS tube, I've made a channel shaped steel beam so everything is going to be custom, but just can't decide what type of bearings to use.
www.topcatcustom.co.uk |
19th Sep, 2012 at 11:55:52am
what makes you think rod ends aren't up to the job? I seriously doubt it! |
19th Sep, 2012 at 12:02:26pm
The way they would have to be mounted, and the fact that there would probably be thread sticking out which is a weak point. Also depending on the design they may cut into valuable space between the tyre and beam (is always tight there even with standard components and big tyres). www.topcatcustom.co.uk |
19th Sep, 2012 at 12:08:37pm
I understand your concern, I thought that myself until I saw how a rod end fails. Amazingly the thread seems to be the strongest part.
114 Posts Member #: 9645 Advanced Member South Wales |
19th Sep, 2012 at 12:16:32pm
Guess the side loads would be an issue with ball bearings, you would need some kind of washer like on the standard radius as you said to limit this.
Edited by minivan63 on 19th Sep, 2012. |
19th Sep, 2012 at 01:19:20pm
Paul, that was my third option! I am making some custom rear subby mounts for a prototype new Mini with those at the moment, but I thought to myself that with a classic mini radius arm set up, both bearings will be dead true to each other so there is no point using spherical bearings which are good for allowing mis-alignment but no real need on a "true" axle in effect.
19th Sep, 2012 at 01:36:37pm
Just use standard trailing arms rebuild kits then, theyre well proven I seriously doubt it! |
19th Sep, 2012 at 01:54:18pm
If you use POS rod ends, then you might have problems. If you use the high quality Rod ends, then you will not have problems. If you have any doubts about the strength of rod-ends, ask yourself what is so different from a front suspension double-wishbone setup as seen on many custom race cars (aside from two, instead of one arm of course)
Edited by turbodave16v on 19th Sep, 2012. On 17th Nov, 2014 Tom Fenton said:
19th Sep, 2012 at 02:03:49pm
Dave, I know what you mean, the grasstrack minis look like a decent lightweight setup, but they don't use all the available width to the ends of the heelboard like most minis do, may not matter but I'm just picturing sliding sideways into ruts etc the amount of force going into the set up, which only stage rally cars really have to put up with.
19th Sep, 2012 at 02:19:45pm
Forget grasstrack Minis, try twin bike engined 350bhp hatchbacks that also use trailing arms with rose joints, and spend 1/2 the lap sideways over lumps bumps and ruts. Yes theoeretically rose joints have some limitations, but go up a size and they are more than strong enough for the job in hand.
19th Sep, 2012 at 02:20:52pm
TC, if you look 16 images down on my page you will see my version of this very setup. Dont reinvent the wheel one of these Autotest Car endured the greatest side load possable for a mini, these rod ends are M10 size made by SKF they are boom proof this car has done 200+ autotests with no signs of wear or brakage
On 17th Feb, 2009 Rob H said:
19th Sep, 2012 at 02:31:15pm
Paul, I saw that build thread, very interesting. I like your use of the rod ends mounted on the car instead of on the trailing arm, it does mean having the thread sticking through the heelboard though which is why I dismissed the idea originally, however I don't see why it would be a problem actually! Will think about that, might be the best solution, I reckon a big "O" ring around the thread between the heelboard and beam would stop any shit going through into the car too.
19th Sep, 2012 at 03:42:21pm
TC, We really had no problem with water or crap getting in where the holes in the Heal board are drilled just use Alloy washers instead of the standard steels ones and they will seal grand.
19th Sep, 2012 at 05:16:50pm
Excellent cheers Paul, I think my rear beam may be a little overkill too now.....
19th Sep, 2012 at 06:29:01pm
paul did you ever say what that car weighed ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
19th Sep, 2012 at 06:37:05pm
Where i used to work, we used to use rod-ends on bottom arms. fitted to forest spec, pug 205 rally cars.
David. |
19th Sep, 2012 at 07:08:54pm
Robert I did not but I think its some where around 440 and 450 only weighed it on a Sand and Gravel weigh bridge so not very accurate, It just got some new alloy rear arms and front hubs as well as some split rims so we are probably near 430 now I would hope. sorry for the Post Hijack On 17th Feb, 2009 Rob H said:
