Home > Beginners Tech > Help which wiring loom
Mini_mark
Member #: 10112
Doncaster
Hi all im new to tm I am removing my 998 and replacing it with a metro turbo but not sure which wiring loom to use iv took my loom out as I looks really tired and the car is gettin resprayed any one know which would be best to buy any help woud be very much appreciated
Standard loom for your car. What year is it?
In essence, you are fitting a 1275 with electronic ignition. So there is nothing special about the wiring. Does you current loom work? If so, stick with that.
You'll just need to power the fuel pump and your mapped ignition (if you run one)
Mini_mark
Member #: 10112
Doncaster
My car is a 86 mayfair old loom works but things have been added and messed with by previous owners
steve1275
Member #: 951
Bromsgrove
Autosparks have all the standard looms and will make you a bespoke one if you tell them what you want.
'Where does the engine go?'
Mini_mark
Member #: 10112
Doncaster
Thanks for the help ill keep my loom ill just get a auto electrition to look at it ant tidy it up thanks for the help im sure there will be more from me
Don't bother with the auto electrician. It shouldn't be too hard to trace back and remove the extra stuff. The mini loom is dead easy.
Mini_mark
Member #: 10112
Doncaster
sorry to be a pain but how would I wire up the ecu with the 998 loom thanks for all the help
What ecu? the one from the metro? Put that in the bin.
Mini_mark
Member #: 10112
Doncaster
Lol was looking into it last night its going in the bin thanks for the help
Mini_mark
Member #: 10112
Doncaster
Edited by Mini_mark on 1st Oct, 2012.
