| Home > Beginners Tech > Indicator help | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
22nd Sep, 2012 at 08:14:52am
My hazards work but my indicator stalk seems to
22nd Sep, 2012 at 08:19:06am
you get 12v supplied to the stalk, this gets split between left and right indicators, then off to either side of the hazard switch, which then sends it of to the lights with a flasher in line somewhere. time to get your multimeter out and see what gets power and when. Sounds like either the hazard switch or the stalk at fault. On 11th Feb, 2015 robert said:
22nd Sep, 2012 at 08:38:41am
ok thanks.
![]() 90 Posts Member #: 9838 Advanced Member |
27th Sep, 2012 at 03:46:27pm
On 22nd Sep, 2012 apbellamy said:
you get 12v supplied to the stalk, this gets split between left and right indicators, then off to either side of the hazard switch, which then sends it of to the lights with a flasher in line somewhere. ......... Are you sure? I thought the +ve feed was to the hazard switch first. Then via the flasher unit to the stalk. When the hazard switch is in the 'off' position it connects the bottom two pins feeding the stalk. When it is switched to the 'on' position, it disconnects the two bottom pins and connects the other 4 pins feeding the 4 corners at the same time. So the problem could also be a faulty hazard switch. Steve
27th Sep, 2012 at 04:59:23pm
That was how I read the diagrams and wired my car... On 11th Feb, 2015 robert said:
