Home > Help Needed / General Tech Chat > med pinion support housings
pieter
Member #: 7577
belgium
hi guys,
i recently bought a med pinion support housing for the dog box i am putting together at the moment.
anybody has fitted one before?
and how can you make it fit onto the subframe as the support housing is narrower than the original speedo housing?
I've fitted one.
It comes with some spacers and bolts so that you can fit the original aluminium support block, the thing with the single countersunk screw hole. The rad/engine mount bracket fits to that in the usual way.
pieter
Member #: 7577
belgium
thanks paul,
i have sorted that one out over lunch so i can mount the gearbox.
JT
Member #: 637
Hertfordshire
I've been looking for info on this but can't seem to find any!
Do people think that this is a worthwhile mod? To a high powered turbo mini?
Any reviews on the KAD version?
Regards,
Josh
My build thread..
I have the Kad one fitted, the only thing I can find wrong with it is that it's a little more nosey on tick over,
JT
Member #: 637
Hertfordshire
Ok that's interesting lol. Wonder why?
Was it a straightforward fit?
Can you still use the standard speedo gear?
My build thread..
