Home > Help Needed / General Tech Chat > Radiator, intercooler and alternator
snowfruit
Member #: 557
Ireland
Which of these would be better mounted at the front, do I get a front mounted radiator, or mount the intercooler at the front and leave the radiator where it is. Is there anything besides the alternator that's going to get in the way?
I know the swift alternator is recommended as a smaller unit. But there are loads of japanese bike alternators on ebay, would any of these do the job?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Nissan Micra's are suppost to have small alternators according to some programm on Motors TV yesterday!
Alex
AlexF
Get the intercooler up front, you shouldn't have any trouble with a decent side mounted rad. You could always add a small auxiliary rad if needed.
You'll find the dizzy and the starter motor with the piggy back solenoid will limit how much space you have. Using a side exit dizzy cap and a starter with seperate solenoid frees up a little more space.
Phil. *smiley*
snowfruit
Member #: 557
Ireland
Where could I get the dizzy and starter Turbo Phil?
Nissan micra's have the slightly larger NipponDenso alternator ie larger than the swift/charade unit - so that sounds like a bollox program!
Dangerous
Member #: 417
charade 3 cylinder 900?cc easy to wire up
Da Daaaaaa!
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2995
Bike alternators are usually gear /shaft driven. Guess you could modify them?
Some mini-diggers and generators have motorbike sized alternators - probably a better bet - but not much power output mind!
Edited by turbodave16v on 2nd Jun, 2005.
