Home > For Sale > Bedroom Clearout Take 2 - Intercooler's, Copper Fuel line, Carb, T2 Core, Braided oil feed etc etc
Craigie-B
Member #: 9468
Wootton Bassett
Hello chaps!
It has come to that time where my blackhole of a mini needs more money, so I offer the following parts for sale:
All prices do not include postage & packaging and also either send paypal money as a gift or with enough to cover fees which you can work out here please:
http://www.clothnappytree.com/ppcalculator/
I am back at Uni so this means that I am in Coventry at the minute and the stuff is up with me there soo feel free to collect from CV4 or I will be happy to post stuffs
Okay heres what I am selling:
Audi 20vt Intercooler with brackets to fit! £SOLD
Bought from Rob, however used another Intercooler instead. Comes with all brackets to make it fit under a standard roundnose, some bent fins but in good nick still.
Golf 20vt Intercooler. £25.
Almost Brand new condition, only a few bent fins nothing really noticeable. Comes with the standard cowling however one of the lugs holding this on has been removed but the cowling still holds, all the standard mounts are still attached apart from 1
Renault 5 GT Turbo Intercooler. £15
Renault 5 Turbo core and compressor housing. £30
I'm pretty sure the core needs re-building as its oilly. There was no play in the wheels but like I said previously I'm pretty convinced its knackered. Comes with the compressor housing and the circlip to hold it in place.
Standard T3 Braided oil feed. £SOLD
Brand new, no damage fits a standard T3 setup
Metal 6 Blade fan. £20
Brand new, has a few marks and scratches on it from where I fitted it to my engine and then was removed, not bent or anything like that.
11 Blade Plastic fan. £SOLD
Not broken, should work perfectly fine, removed from 998 Engine.
MiniSport 1275 Ultimate Engine Steady. £SOLD
Brand new, didn't use in the end as I had to cut a bulkhead box, currently unavailable from minisport as they are out of stock. Even comes in the original Box :)
Braided Oil Cooler Hoses. £20
Brand New, I installed them and then bought an astra oil cooler which these wont fit. Some damage on them as they were on the engine before we fitted it in the car.
~5m of 8mm OD Copper Pipe. £15
Brand New, I bought 10m of this stuff to do my fuel line with and have about 5m left. Builder uncel tells me its roughly 1m per coil and theres 6 coils left. All brand new never unwound exactly as it came from B&Q!
6M of 6mm Nylon Hose. £15
Brand New, same as above never unwound from the reel no kinks or bends in it.
Pair of front top suspension arms. £20
These will definitely need refurbishing however they are perfectly serviceable.
Universal Air Filter. £5
The end of the filter takes a 3" pipe, can get measurements if you want.
Volvo 480 Turbo T2 actuator. £10
Cut the bracket off, however the actuator hasnt been harmed. Could still be of use with a custom bracket?
1/8 NPT 90 Degree fitting. £SOLD
Brand new never used. Fits into the engine block where the oil feed and oil pressure switch takes off used to turn the feed 90 degree so didnt hit the intercooler in my case:
You can see the oil feed here:
T2 Turbo Flange. £SOLD
Brand New, Hasn't been modified or touched as I had another T2 flange which I used instead.
Standard Metro Sandwich plate. £10
Been powedercoated black, in really good nick.
Mini SPi Sandwich plate needs some attention. £6
Bought from R1minimagic on TMF but failed to tell me the condition of it,will need the spout either building back up or chopping off a bit, the part that goes on the cylinder head has a few lumps out of it could do with a skim - maybe okay, but I didnt want to chance it
Mini Thermostat housing with brass pipe in top. £7
I think it was home made, could be ideal for someone to return the water from the turbo?
Passenger Side Engine mount bracket £10
Came with my engine, but I used the one off my old 998, comes with a free old engine mount.
Fully Working HS4 Carb. £40
Taken from 998 engine, fully working no issues when removed been in my bedroom with the rest of this stuff since.
Engine Steady Bracket. £5
Found this after i had replaced it! No cracks or splits, good condition, although a bit grubby.
Standard Engine Steady. £SOLD
Came off of my 998, DOES NOT come with the yellow poly bushes, will come with 4 Brand New Rubber bushes.
Standard Oil Return. £7.50
Doesnt come with the metal pipe that goes between the feed and the pipe. No splits or cracks.
Unknown Bracket. £3
I cant remember what this was from, It was in with my altenator bracket. No cracks, good condition.
Clutch Cylinder with Metro Damper. £7.50
Removed from the turbo engine as the 998 one was still attached. Pipe looks home made, however its not split. No rubber piece with it.
Volvo 480 T2 Exhaust housing. £15
I dont know if this is any good to you guys, standard volvo 480 turbo exhaust housing. Has the wastegate built in, 1 of the nuts is missing for the exhaust pipe end and 1 of the bolts holding the clamps to the turbo got chewed up so I binned it.
Brake Servo Pipe. £5
Standard Brake servo pipe taken off of the manifold.
1275 Turbo Coil. £3.50
Used coil, came attached to the turbo engine.
Simplex Timing Chain. £3
Brand new, never used. Bought it then went duplex as I upgraded engine
Air duct for heater. £5
Removed only to make room for Intercooler. No holes, fits just fine.
Blue T-Piece 2x10mm ends and the spout is 8mm. £3
Was going to use to return water to the engine but where I planned to use it wasn't going to work.
All prices are ovno Collection from Coventry, postage will be extra ontop.
These items are for sale on other forums and on facebook groups as well.
Craig
Edited by Craigie-B on 7th Oct, 2012.
pm'ed
Craigie-B
Member #: 9468
Wootton Bassett
2 of the 90 deg pieces sold.
Forgot to mention I will be at coombe this sat so can take parts off of me then
I'll take that flange.
Craigie-B
Member #: 9468
Wootton Bassett
2 x 90 deg fittings
T2 Flange
All sold pending payment
adam1330
Member #: 238
essex
pm sent.
jarmour116
Member #: 10044
Ballymoney, NI
pm'd :)
Craigie-B
Member #: 9468
Wootton Bassett
PM'd Back and Updated!
Craigie-B
Member #: 9468
Wootton Bassett
Updated with sold bits
Craigie-B
Member #: 9468
Wootton Bassett
Updated with more sold bits
Feel free to make offers!!
jamiestevenbell
Member #: 9941
Derby
Is the thermostat housing with copper pipe in it still spare if so how is that brass bush actually held in? I'd it threaded or just some sealant holding it together
jamiestevenbell
Member #: 9941
Derby
Craigie-B
Member #: 9468
Wootton Bassett
yes it is, the copper pipe into the top? Not 100% tbh mate I can get some better pics if you want?
