| Home > General Chat > weak spark | |||||||
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
27th Sep, 2012 at 09:28:08pm
Bloody Mini won't start again.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
27th Sep, 2012 at 09:33:15pm
non balast coil on a balast car? ie the coils only getting about 9v
28th Sep, 2012 at 08:39:44pm
The car is 92 low comp 1275 so when I swapped it for a 998 (long story) I fitted it with the electronic ignition from the 1275.
Rusty by nature
15th Oct, 2012 at 08:07:38pm
After some time fooling around I borrowed a booster (additionnal battery for starting, I dunno if you call it this name) and it now starts !
Rusty by nature
15th Oct, 2012 at 10:38:45pm
On 15th Oct, 2012 Advantage said:
Apparently my battery had enough power to crank the engine for extended periods but not enough for the coil ??? My battery chargers seem to think it is dead too ... my battery did this for a while one of the cells died not long after, strangely i think it was related to a starter issue ( burnt out 5 starter motor armatures ) Yes i moved to the darkside |
20th Oct, 2012 at 09:06:54pm
With the help from a battery booster, a swap of carb and boost of gaskets with some blue gunk, the car was made to run properly (timing was out too)
Rusty by nature
