| Home > Help Needed / General Tech Chat > Any tips for an oil-leak free engine rebuild? | |||||||
29th Sep, 2012 at 11:59:50am
I have a decent quality block/gearbox gasket set and plenty of patience but are there any tips for minimizing the chances of an oil leak? Should I just use dry gaskets for the block/gearbox and front plate or should I use sealant as well? Any help appreciated! On 7th Nov, 2008 Nic said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
29th Sep, 2012 at 12:03:54pm
i used good sealant on all joints and iv got an oil leak free engine Done now needs redoing lol |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
29th Sep, 2012 at 12:24:28pm
http://www.amazon.co.uk/gp/aw/d/B002J9E4UC...8454023-7903151
29th Sep, 2012 at 12:57:12pm
Stag Wellseal. All other known gasket goo pales into insignificance.
29th Sep, 2012 at 01:39:11pm
Good prep and the thinnest slither of sealant on evergthing Edited by Brett on 29th Sep, 2012. Yes i moved to the darkside |
29th Sep, 2012 at 01:58:40pm
Like he says. Half the battle is careful assembly, with all mating surfaces clean and true. |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
29th Sep, 2012 at 05:10:00pm
Don't put oil in - joke! |
29th Sep, 2012 at 05:17:39pm
As brett says good prep is key, clean ans oil free mating surfaces and a smear of gunk and youll be away 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
29th Sep, 2012 at 10:42:45pm
Speedysleeve on the crank pulley is what finally gave me a leak free poer unit. On 17th Nov, 2014 Tom Fenton said:
30th Sep, 2012 at 12:06:44pm
OK thanks for the help guys. I usually use some kind on sealant, I got good results once but last time had a leak at the timing cover end and the rear gearbox selector. On 7th Nov, 2008 Nic said:
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
30th Sep, 2012 at 11:03:55pm
Your very lucky to get an A series engine not have a small leak some where, after a short while after building I find you start to get the classic leaks such as the rod change to the gearbox is favorite, diff drive flanges, timing cover oil seal.. Main Build
1st Oct, 2012 at 07:05:23pm
On 30th Sep, 2012 nala56 said:
Your very lucky to get an A series engine not have a small leak some where, after a short while after building I find you start to get the classic leaks such as the rod change to the gearbox is favorite, diff drive flanges, timing cover oil seal.. Pretty much the leaks I get. I have the minspares leaky kit thing for the rod change but noticed it was still leaking. Also timing cover oil leaks, seams to be anywhere where there's a seal. On 7th Nov, 2008 Nic said:
