Home > Help Needed / General Tech Chat > Dont think in far off for engine mods
Scudy23
Member #: 10087
Very wet south wales
But please point out anything i would need to add for a 998 turbo :
998 +.020 dished pistons
12g295 slightly ported but may get skimmed
Metro turbo cam
T2 turbo, elbow and acuator
duplex timing gear
Hiff44 carb ( may need to rebuild ? )
Still to get :
Rebore for pistons
Carb manifold
Plenum < why is this need ? To run an intercooler ?)
Build up head
Get head skimmed
Anything you guys can add to the list for me ?
1 question my petrol tank has an intank pump, would i need to get a different one ?
Edited by Scudy23 on 2nd Oct, 2012.
Mpi tank is good for lots of boost, Spi should be on for 12 or so psi.
You need to decide what CR you are aiming for before you will know what dish you'll need in the piston or how much needs skimming off the head.
The plenum is essential unless you want to make things awkward.
metro turbo cam = shite as its just a 1275 cam.
You want an N/A MG Metro Cam (unless you are building a mild motor)
the plenum is there to keep the fuel pressure above the boost pressure so that you don't run out of fuel when you are thrashing about and break your engine.
The metro turbo cam is just a standard 1275 cam. I would go for an MG metro cam instead.
Mike-998
Member #: 9774
Buckinghamshire
Make sure the hif44 is a turbo carb (they can be converted, but is a bit of a bodge) and what are your exhaust manifold plans?
Scudy23
Member #: 10087
This is the cam i bought dont really know how to id it
As for manifold looks like its either the mirage or may see the mechanic i use to see if he can build one, hes reasonably priced for other things.
What tank would i have in a my91 Was under the assumption that it was only te mpi tank which was built in but must have my wires crossed.
Scudy23
Member #: 10087
So the hif44 i just bought is a bag of shit then i take it ?
Scudy23
Member #: 10087
Going by what wil on here has said the pistons i have ( 20773 ) have a 6cc dish and would give me a CR of 8.5.1 i think it was.
how is it a bodge?
Scudy23
Member #: 10087
More to the point brett, is it easy , i thought i just had to rebuild build it.
Also just noticed there alot of mini owners from yorkshire too
Mike-998
Member #: 9774
Buckinghamshire
Well, personally I'd rather run a turbo car with a turbo carb, one designed to do exactly the job i'm asking it to do.
Scudy23
Member #: 10087
I have looked for a turbo carb but everything was advertised a just hif44, what would i need to convert it ?
maccamcvey
Member #: 6673
Worral Sheffield
have a search....!
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
Craigie-B
Member #: 9468
Wootton Bassett
Thats the cam I sold you on TMF, it came out of my turbo engine which was entirley standard other than a + 20 rebore when I got it
Scudy23
Member #: 10087
Ai you hadnt run it you said didnt you, if its a turbo cam according to the guys above its gonna be a normal 1275 cam which im gonna have to change......wanna buy it back ? Lol
Craigie-B
Member #: 9468
Wootton Bassett
I was going to use it tbh mate, but it was one of those "while its in bits I may as well put a new cam in" I went for the kent 266 but from what people have said I would go for the phase2 cam if i take the engine apart again
