| Home > Help Needed / General Tech Chat > Recommend me an exhaust... | |||||||
![]() 117 Posts Member #: 9966 Advanced Member Norwich, Norfolk |
2nd Oct, 2012 at 08:06:13pm
Evening guys,
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
2nd Oct, 2012 at 08:11:05pm
Was using stainless fletcher system, no issues and I thought a good price On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
2nd Oct, 2012 at 08:13:01pm
What are you using it on? Or have I missed a build thread somewhere. On 7th Oct, 2010 5haneJ said:
2nd Oct, 2012 at 08:17:18pm
On 2nd Oct, 2012 minimole23 said:
What are you using it on? Or have I missed a build thread somewhere. Sorry, should explain - no build thread yet as im lazy :-p its a 1275 T2, in a 71 clubman. running 10psi boost, but i'll be upping that next year, so silencer needs to be up to that. :) |
2nd Oct, 2012 at 08:21:33pm
I'd probably just go with a 2 inch maniflow one. On 7th Oct, 2010 5haneJ said:
2nd Oct, 2012 at 08:29:05pm
I rate the maniflow exhausts highly. Don't use anything else. On 11th Feb, 2015 robert said:
2nd Oct, 2012 at 08:29:44pm
Cherry bombs arnt even loud 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2nd Oct, 2012 at 08:33:54pm
Maniflow it is then by the sound of things.
2nd Oct, 2012 at 08:35:24pm
I use a fletcher side exit stainless box and a stainless link pipe with a mid box. passes noise regs I run a supercharger and I don't care the TB is on the wrong side.
2nd Oct, 2012 at 08:37:24pm
Do fletchers come in 2.5 inch? Could be a solution? |
2nd Oct, 2012 at 08:47:47pm
I dont know I have a 2" but they do have a slightly larger exit. I run a supercharger and I don't care the TB is on the wrong side.
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
2nd Oct, 2012 at 08:48:13pm
I would go for a flecture system, that what I am using on my clubby estate, sounds amazing, and really good quality.
2nd Oct, 2012 at 09:33:27pm
I have a 2.5 inch playmini and it expels the gasses fine Crystal Sound Audio said:
2nd Oct, 2012 at 09:34:25pm
thanks guys.
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
2nd Oct, 2012 at 09:44:33pm
I'll add in a vote against Maniflow.
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
2nd Oct, 2012 at 09:49:07pm
Thats odd, I'd not heard much bad about maniflow and almost bought a custom one for myself yesterday.
On 2nd Oct, 2012 Carl S said:
I'll add in a vote against Maniflow. Although it was easy to fit and sounds/looks nice, I can't recommend it if you're going to use the car regularly on the road and want it to last a long time. I've had a Maniflow system fitted to mine since early 2009 and it was on the road daily for about 2 years in total up to now. Both of the back boxes are now scabby as hell with rust, and it is not just on the surface as I had the whole lot off the car not long ago. However, this may be the same story for all other systems that you can buy, I am of course just sharing what I've found so make of it what you will. :) http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
2nd Oct, 2012 at 09:59:57pm
It could just be that I drove the car in all winds and weathers, as it was my daily car for quite a while.
2nd Oct, 2012 at 10:10:43pm
I'm after an exhaust for my daily at the moment, and thought maniflow would be a sensible option. I'll make sure to speak to them about warranty now.. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
3rd Oct, 2012 at 07:08:59am
Any mild steel exhaust will rot over time, especially if used in winter. If you don't want rot, buy stainless. On 11th Feb, 2015 robert said:
3rd Oct, 2012 at 07:59:35am
On 3rd Oct, 2012 apbellamy said:
Any mild steel exhaust will rot over time, especially if used in winter. If you don't want rot, buy stainless. Indeed, that's why I'll be buying a stainless system next time
3rd Oct, 2012 at 08:08:37am
Thanks guys.
