Home > Help Needed / General Tech Chat > strange engine number
turbochargedstu
Member #: 908
gateshead
anyone help with ident of this engine number. cant find it on searches
99H249A-H1431
cheers
stu
balls to the blower!!!
its a 998 mate
turbochargedstu
Member #: 908
gateshead
cheers. iknow its a 998 but trying to find out what its out of. its got a wierd square airbox on it and a late unleaded head.
shellspeed
Member #: 9580
Surrey
Most sources indicate 99H is mini 1000.
The 249a is more difficult as the narrow down. Guessworks has a decoder on his web site but it does not go that low.
turbochargedstu
Member #: 908
gateshead
yeah looked on the guessworks site and had no luck. i cant find reference to it anywhere.
99H - H - comes up as last of the Mini 1000 (1969)
I wonder if that is the same as The Last Of The V8 Intercepters
turbochargedstu
Member #: 908
gateshead
last of the mini 1000 in 69? wasnt it only coopers, elf's and hornets what had the 998 fitted around that time?
http://www.minireg.com/disp_auto.asp?autoid=427
turbochargedstu
Member #: 908
gateshead
not sure thats accurate though because im fairly certain riley elf engine numbers start with 9wr.
Johnny
Member #: 6926
Accrington
i have a block that has a 99h stamp on it but its definately a standard bore 1275 and it looks to have been turboed. because its got the oil return bolted on it.
That is not the original number then.
all the non cooper 1275 varients were started 12, and all the 998's starter 99. See a pattern? The cooper varients al started with 9F
99H - H 998 A L n/a n/a Last of production (1969) (last of production what? this was at the top of the 9F cooper list, so is it the last of the 998 production cooper engine? no idea, but its the clossest match to what you have
9AD 998 A L F C Austin, Wolseley Hornet/Riley MKII with remote gearbox, closed circuit breathing
9AE 998 A L F C Wolseley Hornet/Riley Elf MKIII
9WR 998 A L F C Wolseley Hornet/Riley Elf MKII pre closed circuit breathing
99H - 101 --> 998 A L D C Wolseley/Riley Mini Clubman, Mini 1000cc 1970 on MKIII
99H 791 998 A L D C Mini 1974 on
99H 907P 998 A+ L F C Metro, 9.6:1CR, A series Main caps
99H 962P 998 A+ L F C 3.44 FD, 9.6:1CR (Slimer)
99H 997 --> 127421 998 A+ L F C 2.95 FD, A series Main caps
99H 997 127422 --> 998 A+ L F C 2.9 FD
99H A06 --> 08 998 A+ L F I Metro, 10.3:1CR
99H A53P 998 A+ L F I
99H A64P 998 A+ L F I Metro, 8.3:1CR
99H A65 --> 66 998 A+ L F I Metro, 10.3:1CR
99H A67P 998 A+ L F I Metro, 9.6:1CR
99H A68 --> 69 998 A+ L F I Metro, 8.3:1CR
99H A70P 998 A+ L F I Metro, 10.3:1CR
99H A71P 998 A+ L F I Metro, 9.6:1CR
99H A75P 998 A+ L F I Metro, 10.3:1CR
99H A97P 998 A+ L D C 3.44 FD, A Series Main caps, A series Gearset, 12" wheels
99H B38P 998 A+ L F I Metro, 9.6:1CR
99H B39P 998 A+ L F I Metro, 8.3:1CR
99H B81 --> 127431 998 A+ L F C
99H B81 127432 --> 998 A+ L F I
99H B83P --> 102908 998 A+ L D C
99H B84P --> 100216 998 A+ L D C
99H B87 --> 89 998 A+ L F I Metro, 9.6:1CR
99H B90 --> 93 998 A+ L F I Metro, 10.3:1CR
99H B94 --> 95 998 A+ L F I Metro, 9.6:1CR
99H B96 --> 99 998 A+ L F I Metro, 8.3:1CR
99H C20 --> 105023 998 A+ L F C
99H C20 105024 --> 998 A+ L F I
99H D27 --> 31 998 A+ L F I Metro, 10.3:1CR
99H D30P --> 31P 998 A+ L F I Metro, 9.6:1CR
99H D32 --> 35 998 A+ L F I Metro, 8.3:1CR
99H D80 998 A+ L F I
99H D81 998 A+ UL F I
99H D83P 102909 --> 998 A+ UL D I
99H D84P 100217 --> 998 A+ UL D I
99H E20 998 A+ UL F I
99H E21 998 A+ UL F I
99H E22 998 A+ UL D I
99H E35 998 A+ UL F I Metro, 9.6:1CR
99H E38 --> 39 998 A+ UL F I Metro, 8.3:1CR
99H E67 --> 998 A+ UL F I Metro, 9.6:1CR
99H F15 998 A+ UL F I
99H F16 998 A+ UL F I
99H G30 998 A+ UL F I
99H G31 998 A+ UL D I
99H G32 998 A+ UL F I
99H G33 998 A+ UL F I
