Home > General Chat > building loft in garage
I am at a point where i need to build some space in my garage loft, either side of my garage running down the length of the garage is two big joists these are around 300mm x 100mm and are 3mtrs apart, i intend to put some structual timbers across between these joists and board out a section, is these a formula to work out what size i can use? i was thinking 100x47 would be strong enough but have the option of 125x47 and 150x47 however they abviously get heavier and would be harder to install
any thoughts
you will be able to find Trada span tables on the web that will give you the size and spec for the new timber. However, this would all depend on the loading the existing joists are able to carry, bearing in mind waht they may already be carrying
Neil you fucking puff, 150x47 is a 6x2 and at 3m long is not in any way shape ofr form heavy,
at a 3m span i would be looking at 7x2 @400 mm c/c min depanding on what you intended to load it with,
carl
since when was 47mm 2"?
When it's planed edge
Andy , a little lesson in timber sizes, 97x47 is 4x2, 145x47 is 6x2, and so on, these sizes are uaually prefixed by the term ex, meaning "from"
ex 4x2 is acctually sized to 97x47.
which is approximatly the size i will be batting you around the head with if i get any more clever twat quips,lo
carl
Dont forget i have a damaged rotator cuff and labral tear in my shoulder *wink*
I actually bought 150mm today i do think 150 is overkill but sod all price difference compared to 100
carl
tadge44
Member #: 2500
Buckinghamshire
I would be looking more closely at what Rob said in that you are going to add load to two beams that (presumably) are already carrying roof loads for which they were calculated.
As long as you are only going to put light stuff up there you should be OK, but we all start out with those intentions !
It is only for light bulky stuff that takes up room
