| Home > Help Needed / General Tech Chat > reverse gear problems | |||||||
5th Oct, 2012 at 03:49:47pm
hi all
5th Oct, 2012 at 03:56:54pm
I would look at worn selector arm, the gear in back to front and the brass bush in the gear starting to come out of the gear. On 11th Feb, 2015 robert said:
5th Oct, 2012 at 03:59:13pm
cheers, i will take a close look at these points when i pull the engine and inspect the gearbox |
5th Oct, 2012 at 04:03:13pm
Could also be worn 1st/2nd synchro hub not engaging reverse correctly. On 11th Feb, 2015 robert said:
5th Oct, 2012 at 04:06:21pm
what do you look for on a worn synchro hub? if it was worn would it have an effect on 1st/second gear? cheers, dan |
5th Oct, 2012 at 04:25:15pm
When you engage reverse the teeth on reverse mesh onto teeth cut into the outer ring of the synchro hub and rotate it the other way against first gear. On 11th Feb, 2015 robert said:
5th Oct, 2012 at 04:32:35pm
Reverse gear only fits one way. The bush can and does move as Andy said.
5th Oct, 2012 at 06:57:58pm
As above, as Andy says, check!
5th Oct, 2012 at 07:07:28pm
mine had a massive problem jumping out of second on overrun, reverse was very hard to get, to cure mine i bought 2 new roll pins and 2 new rubber bushes for the selector housing,
Edited by Brett on 5th Oct, 2012. Yes i moved to the darkside |
5th Oct, 2012 at 10:50:01pm
thanks for the input, i will check all of these things when i get it apart. i am sure the big ball bearing and spring went in, il have to renew them when i take it apart to see whats what |
3rd Mar, 2013 at 12:57:44pm
hi, bit of a post resurection here. i have pulled the engine and split the gearbox.
Edited by welshdan on 3rd Mar, 2013. |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
3rd Mar, 2013 at 01:46:09pm
Was it difficult to get 1st as well, if so it could have been clutch drag, just a thought.. Alan Main Build
3rd Mar, 2013 at 09:38:01pm
sounds like the clutch system is part falt. as above i think the dent ball n spring in the diff caseing is worth replaseing also the selector arm along with roll pins
4th Mar, 2013 at 12:40:33am
cheers for the input. i stripped the gearbox this afternoon. everything looked in good order apart from the missing dog teeth on the 1st/2nd synchro hub everything else seemed to be in order. if felt good on the hub. the selectors had slight wear to them, i changed them for a set with no evident wear. reverse gear etc looked good, no movement of the bush etc. its all back together now, i have a feeling that the clutch may have been the main problem. the resevoir was half empty, i have refilled the system and will see where is leaking to over the next few days. i have a new slave to try on there. i hope that its sorted now - will report back in a couple of weeks when i have it running again. cheers, dan |
