Home > Wanted > a+ gearbox casing
welshdan
Member #: 1111
s wales
hi all, im after a bare a+ gearbox casing.
it needs to be in very good condition, ie no stripped threads. i also need the matched diff housing etc.
it also needs to have the original sump threads.
one of the stud /boss housing into the bearbox sump on the bottom of the speedo drive side has cracked/broken on mine i believe...hence a massive oil leak!
i was able to do a temporary fix with some locktite/ fibre washers, but im going to sort this problem properly when i pull the engine this winter.
please pm me with what you have,
many thanks, dan
eden7842
Member #: 8852
leicestershire
How much are they worth and I assume ud want it posting?
welshdan
Member #: 1111
s wales
im not sure to be honnest. i have got a few here but as good complete engine/gearbox setups. so farily cheap would be good. otherwise i could use one that i have.
Dan can't you get it ally welded up?
welshdan
Member #: 1111
s wales
can do steve, il probably have to strip the gearset out, in that case i might as well use a good casing
