| Home > Help Needed / General Tech Chat > new built turbo engine | |||||||
22 Posts Member #: 10140 Member Falkirk Scotland |
11th Oct, 2012 at 07:11:49pm
I can get the engine running but only with full throttle being used. As soon as I release the throttle it dies. The engine will not rev up. With ignition on fuel pressure is 3.5 psi, I have also used the T piece method it makes no difference. When I use full throttle it only revs to about 1000 rpm anything less than full throttle it dies. I am wondering if the turbo is blowing at all, How can I check this Or does anyone have any ideas please |
11th Oct, 2012 at 08:54:35pm
Check you have the ignition. Leads correct and then your timing, then come back and tell us what's happening. Then
12th Oct, 2012 at 06:34:54pm
I had set dizzy static where I thought it should be. With the engine running I moved it to where It should not in theory run but it does, So thanks for your input timming was the issue after all |
12th Oct, 2012 at 06:39:28pm
Have you got the dizzy drive in 180 degrees out? On 11th Feb, 2015 robert said:
