| Home > Help Needed / General Tech Chat > Garrett T2 Turbo Newb Question | |||||||
![]() 20 Posts Member #: 10136 Member Belfast Northern Ireland |
12th Oct, 2012 at 10:30:47am
When sourcing/buying a Garrett T2 Turbo - (newb question) does it matter if the turbo is from a petrol or diesel donor car to put on a 1275cc A+engine.
12th Oct, 2012 at 10:37:32am
The 'T' designation for a Garrett turbo refers to construction type rather than its size. However, typically the larger the number the larger the turbo (in physical size and flow).
Edited by wil_h on 12th Oct, 2012. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
12th Oct, 2012 at 10:41:29am
so a Garrett T2 Turbo petrol or diesel donor will do with the compressor A/R or .48 and a turbine A/R or .35 and this is the one you want. - or the GT1544.
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
12th Oct, 2012 at 10:45:06am
more of a guide; you can generally use any turbo you want if it will work. the A/R's are a good place to start.
Edited by t@z on 12th Oct, 2012. |
12th Oct, 2012 at 11:03:31am
The 'v' stands for VNT. Variable Nozzel Turbine (turbo). These are prevalent on diesel cars and not suitable for use really. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
12th Oct, 2012 at 11:15:33am
The GT1548 is very similar to the T2 used on the Renault 5 GT Turbo which has been proved to be OK on a 1275.
12th Oct, 2012 at 11:24:05am
Paul is correct I sausage fingered the GT name
12th Oct, 2012 at 03:39:51pm
cheers folks at least i will end up with the correct turbo now - The GT1548 or the Garrett T2 is suitable for 1275. Edited by MentalMini on 12th Oct, 2012. |
12th Oct, 2012 at 03:46:36pm
T2 is entry level, low boost optimal.
12th Oct, 2012 at 04:12:41pm
On 12th Oct, 2012 Paul S said:
T2 is entry level, low boost optimal. If you want higher boost and power there are better suited turbos. T3 turbo be better ? |
12th Oct, 2012 at 06:35:38pm
Depends what you want. The T2 will make 160bhp, but that's it limit. For a useable road car, 160 is more than enough and the beauty of the T2 is almost supercharger like levels of boost at low rpm. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
12th Oct, 2012 at 07:52:02pm
On 12th Oct, 2012 wil_h said:
Depends what you want. The T2 will make 160bhp, but that's it limit. For a useable road car, 160 is more than enough and the beauty of the T2 is almost supercharger like levels of boost at low rpm. That will do me if its pulling well at low boost thats the ticket and up to 160bhp be fun enough in a mini. no point going mental for a big turbo with huge turbo lag cheers |
13th Oct, 2012 at 07:39:04am
A GT1752 will give you as much power as you want (200 bhp+) with very little lag.
614 Posts Member #: 2153 Post Whore kings langley |
13th Oct, 2012 at 10:33:38am
what kind of boost pressure would you need to make 160bhp? 1293 flowed head about 8.7:1 phase 2 cam?
15th Oct, 2012 at 06:48:08am
On 13th Oct, 2012 apbellamy said:
A GT1752 will give you as much power as you want (200 bhp+) with very little lag. You will always want more boost ![]() so a GT1752 or GT1548 or a T2 Turbo will be suitable for a 1275 cc engine. any idea on a suitable price for these items. |
15th Oct, 2012 at 08:32:21am
A GT1752 will give you as much power as you want (200 bhp+) with very little lag. You will always want more boost ![]() so a GT1752 or GT1548 or a T2 Turbo will be suitable for a 1275 cc engine. any idea on a suitable price for these items. really does depend what you consider suitable and price varies on demand! for example if you get lucky you can get a gt17 for 60+ pounds but on ebay they are listed as sometimes 200+. just have a search and what seems reasonable to you is good enough. |
