| Home > Help Needed / General Tech Chat > Flywheel/ clutch | |||||||
![]() 236 Posts Member #: 10087 Senior Member Very wet south wales |
12th Oct, 2012 at 03:09:23pm
Was wondering is there anyway i can safely remove the flywheel without a flywheel puller, dont fancy damaging it but dont have a puller.
12th Oct, 2012 at 03:14:19pm
Go buy a puller. If something is worth doing, it's worth doing half of. |
12th Oct, 2012 at 03:25:02pm
For the sake of a few quid, buy one!
In the 13's at last!.. Just |
12th Oct, 2012 at 03:36:50pm
more chance of shitting diamonds.... On 28th Aug, 2011 Kean said:
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
12th Oct, 2012 at 03:40:37pm
yeh puller and rubber hammer; the one i had on my 998 was seized on like a mother fucker had to heat it up, bash it and let it be under load day before it popped of |
12th Oct, 2012 at 04:51:29pm
Lol ok no probs cheers guys |
12th Oct, 2012 at 05:14:56pm
Puller :) why they made the tool |
12th Oct, 2012 at 05:28:12pm
http://www.halfords.com/webapp/wcs/stores/...tegoryId_255216
12th Oct, 2012 at 06:45:09pm
B&Q ?
On 12th Oct, 2012 wolfie said:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_216691_langId_-1_categoryId_255216 i found on on sale in b&q for a little over £7 earlier in the week |
12th Oct, 2012 at 06:52:42pm
Very true but just wondered if there was a different way....... Normally a hammer works for me lol
12th Oct, 2012 at 07:15:38pm
You can't go wrong with a good pull. On 11th Feb, 2015 robert said:
12th Oct, 2012 at 08:27:02pm
On 12th Oct, 2012 Scudy23 said:
Normally a hammer works for me lol That'll be the flywheel in a dangerous condition or bent, and the crank potentially bent then. On 7th Oct, 2010 5haneJ said:
12th Oct, 2012 at 10:31:48pm
Im joking mate, to put minds at rest i will be investing in a puller tomorrow or a bigger hammer
On 12th Oct, 2012 minimole23 said: On 12th Oct, 2012 Scudy23 said:
That'll be the flywheel in a dangerous condition or bent, and the crank potentially bent then. Edited by Scudy23 on 12th Oct, 2012. |
13th Oct, 2012 at 07:34:14am
Years ago before I knew any better I used to always get flywheels off the a series using a hammer. More often than not smashing the transfer gear housing in the process.
13th Oct, 2012 at 07:39:59am
yes b&q had a rummage though some sale bins and they were selling off loads of stanley tools, sockets, spanners, ratchet spanners ect ect
B&Q ? On 12th Oct, 2012 wolfie said: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_216691_langId_-1_categoryId_255216 i found on on sale in b&q for a little over £7 earlier in the week Crystal Sound Audio said:
13th Oct, 2012 at 07:40:51am
If you are buying a puller, try and get one from the 60's/70's from ebay. They are of far better quality. I've snapped/damaged loads of the modern poop ones.
13th Oct, 2012 at 09:54:17am
Will take a look later, thanks
On 13th Oct, 2012 wolfie said:
yes b&q had a rummage though some sale bins and they were selling off loads of stanley tools, sockets, spanners, ratchet spanners ect ect On 12th Oct, 2012 Scudy23 said: B&Q ? On 12th Oct, 2012 wolfie said: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_216691_langId_-1_categoryId_255216 i found on on sale in b&q for a little over £7 earlier in the week |
13th Oct, 2012 at 11:45:01am
13th Oct, 2012 at 12:40:53pm
Well im £20 lighter thanks to halfrauds |
13th Oct, 2012 at 01:34:47pm
Why is the 6 bolts with them, i get the jist of it but theres no instruction, 3 gold3 black 3 washers, triangular bit and a thing |
13th Oct, 2012 at 01:50:17pm
3 for verto flywheel and 3 bolds for pre verto as there a different thread, make sure the thread is well greased on the main bolt, the washers go on the 3 bolts you use for your flywheel and the 3 bolts go through the triangle plate and bolt into the flywheel, the thick stepped spacer fits in the end of the crank again make sure its well greased stop the flywheel turning and tighten up ..... a lot
Edited by wolfie on 13th Oct, 2012. Crystal Sound Audio said:
13th Oct, 2012 at 02:35:11pm
And if it's a verto clutch, be patient. They have a small habit of sticking to the crankshaft. 9.85 @ 145mph
13th Oct, 2012 at 04:08:54pm
Thank you guys |
13th Oct, 2012 at 06:33:43pm
dont forget to stand to the side the flywheel can ping off and land on your toes Second this, mine jumped this far 2 weeks ago and went with a big bang. Was an utter twat to get off though!
13th Oct, 2012 at 07:34:14pm
All done, some reason it didnt come off the crank but did give a bang, thought id snapped something first. |
